Homework Help: Wavefunction normalization
  1. Dec 31, 2007 #1
    I'm trying to determine a normalization value, A, for the following wavefunction:
    [tex]\Psi = Ax{^2}exp(-\alpha x)}, x>0[/tex]
    [tex]\Psi = 0, x<0[/tex]
    In the past, I've had an i term in my exponential, so when applying the Normalization Condition:
    [tex]\int|\Psi(x)|^2 dx = \int\Psi{^*}(x) \Psi(x) dx[/tex]
    the exponentials always multiply to equal one, leaving me with an easy route to getting the normalization factor.
    However in this case, I'm left with the following integral:
    [tex]\int|\Psi(x)|^2 dx = \int A{^2}x{^4}exp(-2\alpha x)} dx[/tex]
    ...which seems horrible!
    Can anyone advise what I'm doing wrong here? I'm sure there's a simpler way...
  3. Dec 31, 2007 #2
    George Jones
    Staff Emeritus
    This looks OK.
    Have you ever seen tabular integration by parts?
  4. Dec 31, 2007 #3
    No, you're doing in the right way. Just do your integral by parts now.
    You can use the gamma function to do it faster.
  5. Dec 31, 2007 #4
    Never...
    I tried it in an online integrator and got a horrendous answer so assumed I'd gone drastically wrong somewhere...
  6. Dec 31, 2007 #5
    George Jones
    Staff Emeritus
    I tried (maybe not very successfully) to explain it http://groups.google.ca/group/sci.math/msg/ebd6104dfcc6263c?dmode=source".
    Most of the terms will be zero; remember, as [itex]x \rightarrow \infty[/itex], an exponential dominates any power of [itex]x[/itex].
  7. Dec 31, 2007 #6
    George Jones
    Staff Emeritus
  8. Dec 31, 2007 #7
    OK, I think I've followed that George Jones;
    Which, using your method, I get to be:
    [tex]exp(-2\alpha x) \left(-\frac{x{^4}}{2\alpha} + \frac{x{^3}}{\alpha{^2}} - \frac{3x{^2}}{2\alpha{^3}} + \frac{3x}{2\alpha{^4}} - \frac{3}{4\alpha{^5}} \right)[/tex]
    Which I *think* leads to [tex]\frac{3A{^2}}{4\alpha{^5}} = 1[/tex] or [tex]A = \sqrt{4/3}\alpha{^\frac{5}{2}}[/tex]
    Would someone be able to verify that? I'm paranoid about this being wrong now!!
  9. Dec 31, 2007 #8
    Seems good, from my calculation, as I arrive, too, at
    [itex]1=\frac{3A^2}{4\alpha ^5}[/itex]
    by two differents methods (that is, by the use of the gamma function and with the long method of integration by parts).
  10. Dec 31, 2007 #9
    Awesome, thanks for your help George Jones and Erythro73!
    That technique is awesome - I'll definitely be using it again!!
