Wavefunction of a particle
  • Thread starter einai
einai
27
Quantum question again....
What's the wave function in coordinate space Ψx0(x') of a particle (in 1-D) located at a certain position x0? What about the wave function Φx0(p') in momentum space? Now, consider the totality of these wave functions for different values of x0. Do they form an orthonormal set?
The only thing I know is that if I know Ψx0(x'), I can Fourier transform it to Φx0(p')? But what's Ψx0(x')?
Thanks in advance!
Answers and Replies
HallsofIvy
43,021
970
The wave function of a particle AT a specific x0 is the Dirac delta function δ(x-x0). Of course, the wave function in momentum space is the fourier transform: the constant function. If you know the position exactly, then you have no information at all about the momentum.
einai
27
Thank you! That makes a lot of sense. :smile: However, I'm not sure whether I understand this part of the question -
Does it mean whether all the delta functions at different x0 are orthogonal or not?
HallsofIvy
43,021
970
What does "orthogonal" mean for these functions?
(The delta function is not a true function. It is a "generalized function" or "distribution". But, the same concepts apply.)
einai
27
I think it means if they're the same function, the product should be integrated to one, otherwise it's zero?
Hm.....I multiplied 2 wavefunction and integrate them. It gave me another delta function.
arcnets
508
einai,
I think the trick is that you use substitution.
You got
&int &delta (x-x0) &delta (x-x1) dx.
Now, let y = x-x0.
Then, dx = dy, and
&delta (x-x0) = &delta (y), and
&delta (x-x1) = &delta (y+x0-x1).
So,
&int &delta (y) &delta(y+x0-x1) dy
&delta (x0-x1).
You probably already got that, and it's the orthogonality relation that you want.
arcnets
508
How can I make these math symbols show?
einai
27
You need to put ; after &delta :D.
And thanks for answering my question. I did get the same thing, but I wasn't sure whether that implies orthonormality. Now I know, since I got the solution from the prof. It does imply orthonormality, and I got it right! :)
arcnets
508
Just testing...
∫ δ (x-x0) δ (x-x1) dx = ?
Now, let y = x-x0.
Then, dx = dy, and
δ (x-x0) = δ (y), and
δ (x-x1) = δ (y+x0-x1).
So, ∫ δ (x-x0) δ (x-x1) dx
= ∫ δ (y) δ (y+x0-x1) dy
= δ (x0-x1).
Fine! Learned something!
einai
27
Just testing...
Now, let y = x-x0.
Then, dx = dy, and
= δ (x0-x1).
Looks much better :)!
I didn't use substitution. I just treated
∫δ (x-x0) δ (x-x1) dx
as ∫f(x) δ(x-x1) dx
so when I integrate it, it gives f(x) -> f(x1) = δ (x0-x1).
I'm not sure whether this is a correct method, although it does give me the answer :D.
Suggested for: Wavefunction of a particle
  • Last Post
  • Last Post
  • Last Post
  • Last Post
