Wavelength and linear momentum
In summary, the process for finding the wavelength and linear momentum of photons with energies of 3eV, 50 keV, and 1.0 MeV involves converting the energy into units of Joules and then using the equations E=hc/λ and p=h/λ to calculate the wavelength and momentum respectively. It is also possible to directly use the equation p=E/c to find the momentum without the intermediate step of finding the wavelength.
mss90
29
I had to find wavelenght and linear momenta of fotons with energies of 3eV, 50 KeV and 1.0 MeV
Are these correct?
E=hc/λóλ=hc/E and p= h/ λ
a. 3eV Hence λ=(6.63E-34*3E8)/3=6.63E-26m
p = 6.63E-34/6.63E-26 = 1E-8
b. 50 KeV = 50000 eVλ=(6.63E-34*3E8)/ 50000 =3.978E-30m
p = 6.63E-34/3.978E-30 = 1.66E-4
c. 1.0 MeV = 1 000000 eVλ=(6.63E-34*3E8)/ 1 000000 = 1.989E-31m
p = 6.63E-34/1.989E-31 = 0.0033
[/B]
Hello mss90,
Welcome to PF! :)
Don't forget to first convert the energy (given in units of eV, keV, and MeV) to units of Joules first, before plugging in the numbers.
Alright, can you confirm that this is correct:
3eV * 1.60E-19 = 4.8E-19 J Hence λ=(6.63E-34*3E8)/4.8E-19=4.17E-7m = 0.417µm
p = 6.63E-34/4.17E-7= 1.59E-27
That looks about right, although there might be some rounding errors going on somewhere.
By the way, when calculating the photons' momentum magnitude, you can simply use the [itex] p = \frac{E}{c} [/itex] formula (after converting the energy into units of Joules, simply divide that by the speed of light, 3 × 108 m/s, and you have the magnitude of the photon's momentum. That way you don't need to depend on the λ intermediate step as part of the answer).
Your calculations for the wavelengths and linear momenta seem to be correct based on the given equations. However, it would be helpful to include the units for the final answers (i.e. meters for wavelength and kg*m/s for linear momentum). Additionally, it would be good to explain the significance of these values and how they relate to the concept of wavelength and linear momentum in the context of photons. Overall, your response is well-organized and shows a good understanding of the topic. Keep up the good work!
1. What is the relationship between wavelength and linear momentum?
Wavelength and linear momentum are inversely proportional to each other. This means that as the wavelength increases, the linear momentum decreases, and vice versa.
2. How are wavelength and linear momentum related to the particle nature of light?
Wavelength and linear momentum are two important characteristics of a particle, such as a photon of light. The wavelength represents the distance between two successive peaks or troughs of the wave, while the linear momentum is the product of the particle's mass and velocity.
3. Can the wavelength of a particle change?
Yes, the wavelength of a particle can change depending on its speed and the medium it is traveling through. As the particle's speed increases, its wavelength decreases.
4. How does the wavelength of a particle affect its diffraction pattern?
The wavelength of a particle determines the size and spacing of the diffraction pattern it produces. Shorter wavelengths result in smaller and more closely spaced diffraction patterns, while longer wavelengths produce larger and more widely spaced patterns.
5. Is there a maximum or minimum wavelength for a particle?
Yes, there is a minimum wavelength for a particle, which is known as the de Broglie wavelength. This is the shortest possible wavelength for a particle and is determined by its mass and velocity. However, there is no maximum wavelength for a particle.
15K
15K
