TalonStriker
- 15
There are 2 in-phase radio wave generators at x = 100 and x = 200. The frequency of each wave is 3.2 MHz. Find spot closest to x = 200 such that the interference at that point is maximum.
[tex]\Delta\Phi = \frac{2\pi}{\lambda} \Delta x + \Phi_{0}[/tex]
[tex]v = c = f\lambda[/tex] c = speed of light
I assumed that point d was close to x = 300. So that
[tex]\Delta x = (100-d) - d[/tex]
[tex]\Delta x = (100 - 2d)[/tex]
[tex] 2\pi m = \frac{2\pi}{c/f} (100 - 2d) + 0 [/tex] for some integer m; \Phi_{0} = 0 since the waves are in-phase
[tex] m = \frac{1}{c/f} (100 - 2d)[/tex] cancel out 2 * pi
[tex]c/f * m = (100 - 2d)[/tex]
[tex](c/f * m ) - 100= 2d[/tex]
[tex] d = \frac{(c/f * m) - 100}{2} [/tex]Ignoring d, I solved for m such that [tex]\frac{(c/f * m) - 100}{2} [/tex] was equal to 300. Using the m i found (rounding it to nearest integer), i plugged it back into [tex] d = \frac{(c/f * m) - 100}{2} [/tex] to find d.
Is the method I used correct? What did I do wrong? (Could you please provide me the correct answer & method...i have an exam in 5 hours).
Thanks!
