Homework Help: Waves Question
  1. Apr 26, 2007 #1
    In a large water tank experiment, water waves are generated with straight, parallel wave fronts, 3.00 m apart. The wave fronts pass through two openings 5.00 m apart in a long board. The end of the tank is 3.00 m beyond the board. Where would you stand, relative to the perpendicular bisector of the line between the openings, if you want to receive little or no wave action?
    2. Relevant equations
    [P(n)*S(1)] - [P(n)*S(2)] = (n - 1/2)*wavelength
    sin ANGLE(n) = (n - 1/2)*wavelength/(distance between sources)
    x(n) / L = (n - 1/2) * wavelength / (distance between sources)
    3. The attempt at a solution
    I tried using the third formula, allowing the n be 1, the wavelength 3.00 m and the distance between the two sources 5.00 m, but i don't know what value i should assign x(n) and L. I don't know if i'm doing the question right. Can anyone help?
  3. Apr 27, 2007 #2
    Mentz114
    This sounds like 2 slit interference. The points of no wave motion would be the places where the distances from the slits differ by 1/2 wavelength..
