How to Calculate Time, Weight, and Wavelength in a String with Weight System?
In summary: Suppose the wave y(x, t) that is given in the problem exists on the string.If you took a picture of the string at a particular instant of time, how many wavelengths would you count along the string?You would count the number of wavelengths along the string from the lower end of the string to the upper end of the string.
Vanessa Avila
94
A 1.60-m string of weight 1.30 N is tied to the ceiling at its upper end, and the lower end supports a weight W. When you pluck the string slightly, the waves traveling up the string obey the equation y(x,t)=(8.50mm)cos(172rad⋅m−1(x)−2730rad⋅s−1(t))
a) How much time does it take a pulse to travel the full length of the string?
b) What is the weight W?
c) How many wavelengths are on the string at any instant of time?
Acos2π(x/λ- t/T)
k = 2π/λ
w = 2π/T
v =√(F/μ)
I found the mass of the string by using F = mg and got 0.133 kg. With this mass, I was able to find the density (m/L) which is 0.0831m/kg
for the time, I thought i should do
2730rad/s = 2π/T
T = 2π/2730 rad/s
for how many wavelengths, I thought of doing:
172rad/m = 2π/λ
λ = 2π/172 rad/m, but that was wrong.
OK, except for the units.
2730rad/s = 2π/T
T = 2π/2730 rad/s
You calculated a time here. But is it the time that is asked for in part (b)? What does the symbol T stand for in your calculation?
172rad/m = 2π/λ
I think you calculated λ correctly. But part (c) is asking for "how many wavelengths are on the string".
Oh T stands for the period. How do we use the period to find small t? and how do we find how many wavelengths are on the string? and my bad! I mixed up the units for density. It should be kg/m. Thanks for that!
Can you find the speed of a wave pulse using the information given? Hint: the speed of a wave pulse is the same as the wave speed of the wave y(x,t) that is given in the problem.
I think "how many wavelengths are on the string" means how many wavelengths fit into the length of the string.
So it's v = λ/T ?
T = 2.302E-3
λ = 0.0365 m
v = (0.0365/2.302E-3) = 15.9 m/s
Your answer for v looks right.
Would I then solve for time by doing v = distance/time by using the length of the string as distance?
15.9 m/s = 1.60m/t
t = 1.60 /15.9 = 0.101s
15.9 m/s = 1.60m/t
OK
TSny said:
OK
:) My answer for t was correct for that one. yay!
And now for the weight, I'm not sure where to start.
The weight W probably has something to do with the tension in the string.
would it be 1.30 N as well since it's pulling the weight up?
Consider a free body diagram for the object hanging on the end of the string.
Oh woop. It has Tension up and mg down. I don't have T, but i can solve that by v = √(Ft/μ)
So my Ft is 21 N which means W is also 21 N. That answr was correct! :)
Now for finding how many wavelengths, do I use the λ I solved?
Great!
Sure.
TSny said:
Great!
Sure.
But what equation do I use to solve for the n numbers of wavelenghts?
Suppose the wave y(x, t) that is given in the problem exists on the string. If you took a picture of the string at a particular instant of time, how many wavelengths would you count along the string?
The problem is a little confusing. If you "pluck" the string to get a "pulse", it would not have the form y(x, t) that is given in the problem (which represents a "sinusoidal wave" spread all along the string).
So if it's just a pulse then it's just 1?
oh wait. So i have a string 1.60 m long, and each wavelength is 0.0365
should it then be
1.60m/0.0365 to find how many there are?
But, the function y(x, t) given in the problem is not really a pulse. It is a sinusoidal wave spread along the string. So, there are a certain number of wavelengths that would occupy the string at a given instant of time.
should it then be
Yes!
Likes Vanessa Avila
TSny said:
Yes!
alright! Awesome! Thank you so much :)
You are welcome. Good work.
Likes Vanessa Avila
What is a wave?
A wave is a disturbance or oscillation that travels through space and matter, transferring energy without permanently displacing the medium through which it is traveling.
What is a string with weight?
A string with weight is a physical model used to demonstrate and study the behavior of waves. It consists of a string attached to a fixed point on one end and a weight attached to the other, allowing the string to be pulled taut and vibrate when plucked or disturbed.
What factors affect the behavior of waves on a string with weight?
The behavior of waves on a string with weight is affected by several factors, including the tension of the string, the mass of the weight, and the length and thickness of the string. These factors can impact the speed, frequency, and amplitude of the waves.
How do waves on a string with weight differ from other types of waves?
Waves on a string with weight are considered transverse waves, meaning that the particles of the medium vibrate perpendicular to the direction of wave propagation. This is in contrast to longitudinal waves, where the particles vibrate parallel to the direction of propagation, such as sound waves.
What are some applications of studying waves on a string with weight?
Studying waves on a string with weight can help us better understand the properties and behaviors of waves in general, which has practical applications in fields such as acoustics, seismology, and telecommunications. It can also be used for educational purposes to demonstrate fundamental concepts in physics and wave theory.
