Can Vibrational Frequencies Weaken Water Bonds to Enhance Electrolysis?
In summary, the conversation is discussing the possibility of weakening the bonds of H2O by inducing a specific vibrational frequency. The idea has been in the speaker's mind for years and they believe it could make electrolysis more economical. The other person confirms that the bonds being discussed are between oxygen and hydrogen in the molecule. The speaker suggests using applied oscillations, such as sound waves or other frequencies, to weaken the bonds. However, the other person points out that this idea goes against classical physics and that high temperature electrolysis is essentially the same concept.
navynuclear
Is it possible to weaken the bonds of H2O with by inducing a specific vibrational frequency? This idea had been rolling around in my mind for years. My thought is that if the bonds could be weakened by less energy then electrolysis alone it may become economical. I realize that some research is being done on high temperature electrolysis, yet this theory still requires the input of energy to get to the required . Any ideas?
You're talking about the bonds between oxygen and hydrogen in the molecule itself right?
Yes. I know it sounds a little crazy, but wondering if there may be a correlation between applied oscillation(say sound waves or other frequencies) and bond strength.
1) You are suggesting free energy.
2) "Vibrations" in classical terms does not apply to quantum mechanics.
3) High temperature is the same thing you are suggesting.
I find this idea intriguing and worth exploring further. The concept of weakening bonds with vibration is not new, as it has been studied in other materials such as crystals and polymers. However, applying this concept to water molecules is a novel approach.
Based on current scientific understanding, the bonds between hydrogen and oxygen atoms in water molecules are relatively strong and require a significant amount of energy to break. Inducing a specific vibrational frequency could potentially weaken these bonds, making it easier to break them apart and release the hydrogen and oxygen molecules.
However, it is important to note that the exact vibrational frequency needed to weaken these bonds is not yet known and would require further research and experimentation. Additionally, there may be other factors at play, such as the structure of the water molecules and the surrounding environment, that could affect the success of this approach.
Furthermore, the practicality and economic viability of this method would also need to be considered. While it may require less energy than traditional electrolysis, there may still be significant energy inputs needed to induce the necessary vibrations. It is also important to consider the potential side effects of manipulating water molecules in this way.
In conclusion, while this idea may have potential, it would require further scientific research and experimentation to determine its feasibility and practicality. It is an interesting concept to explore, but more information and data are needed before any conclusions can be drawn.
1. What are "weaking bonds with vibration"?
"Weaking bonds with vibration" is a concept in molecular physics and chemistry where the bonds between atoms in a molecule are weakened or broken through the application of vibrational energy. This can lead to changes in the chemical properties and reactions of the molecule.
2. How does vibration weaken bonds between atoms?
When a molecule is subjected to vibrational energy, the atoms within the molecule start to vibrate and move around. This can cause the atoms to break their bonds with each other, resulting in a weakened or broken molecular structure.
3. What are some examples of "weaking bonds with vibration"?
One example is the process of infrared spectroscopy, where infrared light is used to excite the molecules and cause them to vibrate. This can reveal information about the bonds and functional groups present in a molecule. Another example is the use of ultrasonic waves to break down chemical bonds in industrial processes.
4. Can "weaking bonds with vibration" be used to create new molecules?
Yes, weakening bonds with vibration can be used in chemical reactions to create new molecules. By breaking certain bonds within a molecule, new bonds can form, resulting in a different chemical structure with different properties.
5. Are there any potential risks associated with "weaking bonds with vibration"?
Yes, there are potential risks associated with weakening bonds with vibration. If not controlled properly, it can lead to unintended chemical reactions or damage to the equipment or surrounding environment. It is important to carefully control and monitor the amount of vibrational energy used in these processes.
  • Other Physics Topics
  • STEM Academic Advising
  • Electromagnetism
  • Computing and Technology
