- #1
werson tan
- 183
- 1
why the formula of weight of fluid block is given by the formula of ρg[ (R^2) - pi(R^2) ] 1?
what does the 1m mean here ?
shouldn't it = ρg (pi) (R^2) h ?
2. Homework Equations
The weight of a fluid block is affected by its density, volume, and gravitational force. It can be calculated using the formula: Weight = Density x Volume x Gravitational Force (W = ρ x V x g).
The weight of a fluid block is influenced by its density, volume, and the strength of the gravitational force. Changes in any of these factors will result in a change in weight.
The density of a fluid directly affects the weight of a fluid block. A higher density will result in a higher weight, while a lower density will result in a lower weight.
Yes, the weight of a fluid block can change if there is a change in its density, volume, or gravitational force. For example, if the volume of the block is increased, its weight will also increase.
The weight of a fluid block is directly proportional to its volume. This means that if the volume of the block increases, its weight will also increase proportionally.
