Weight on Earth v Moon
freerider78
The gravitational acceleration on the moon is 1.62 m/s2. If you can barely lift 195 lbf on earth, what would be the max you could lift on the moon (give answer in N).
F=mg
I have a feeling this is a trick question and the answer is the max weight you can lift would be the same here or on the moon. You could lift 6X more mass, but not weight. I'm not sure how to explain this thought. Any help.
Answers and Replies
tony873004
143
I was about to fall for the trick and do the math.
...the max weight you can lift would be the same here or on the moon. You could lift 6X more mass, but not weight...
What's wrong with this?
Ja4Coltrane
225
your answer is good--but I mean, there really is no mathematical explanation. All you are saying is that if you can lift 195 on Earth you can lift the same on the moon because hopefully you don't undergo to much genetic mutation as you are struck with cosmic rays on the moon/on the way to the moon.
freerider78
I know its a good answer, I just don't quite understand why I could lift the same weight here and on the moon. Sometimes its the easy stuff that trips me up.
tony873004
143
Because weight is force, and you're just as strong and forcefull on the moon as you are here. You already figured it out that this same force will allow you to lift 6 times as much mass.
Suggested for: Weight on Earth v Moon
  • Last Post
