Weight vs Torque relation
  • Thread starter dipub1982
Main Question or Discussion Point
I am trying to figure out the torque vs weight relationship. I am working on a software project where I want to create an application to determine the maximum payload on vehicle with rubber tyre on asphalt road.
I am having three parameter
1. Torque
2. RPM
3. Diameter of tyre
based on which I need to determine the payload capacity of a vehicle.
Example 1
Torque = 106 kg.cm
RPM = 10
wheel diameter = 10 cm
Speed will be = 2 X pi X (diameter/2) X (RPM/60) = 5.24 cm/s
Example 2
Torque = 47.19kg.cm
RPM = 200
wheel diameter = 5 cm
Speed will be = 2 X pi X (diameter/2) X (RPM/60) = 52.38 cm/s
Example 3
Torque = 109.20 kg.cm
RPM = 60
wheel diameter = 6 cm
Speed will be = 2 X pi X (diameter/2) X (RPM/60) = 18.86 cm/s
Answers and Replies
CWatters
2,295
Those three parameters aren't nearly enough.
On level ground (and ignoring air drag and rolling resistance) the relationship is via acceleration not speed. eg The torque required to maintain a constant speed is zero because there are no forces to be overcome. On hills it's a different matter.
Related Threads on Weight vs Torque relation
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
13K
