Weird kinematics question
  • Thread starter ice109
(3) A motorist is approaching a green traffic light with speed [itex]v_0[/itex] when the light turns
to amber.
(a) If his reaction time is [itex]\tau[/itex], during which he makes his decision to stop and applies his foot to the
brake, and if the maximum braking deceleration is a, what is the minimum distance [itex]s_{min}[/itex] from the
intersection at the moment the light turns to amber in which he can bring his car to a stop?
(b) If the amber light remains on for a time t before turning red, what is the maximum distance
[itex]s_{max}[/itex] from the intersection at the moment the light turns to amber such that he can continue into the
intersection at speed [itex]v_0[/itex] without running the red light?
(c) Show that if his initial speed [itex]v_0[/itex] is greater than
[itex]v_{0_{max}} = 2a(t- \tau )[/itex]
there will be a range of distance from the intersection such that he can neither stop in time nor
continue through the intersection without running the red light.
kinematics equations
A using [itex]vf^2=v_0^2 +2(-a)d[/itex] is [itex] s_{min}=\frac{v_0^2}{2a} +v_0\tau[/itex]
B is simply [itex]v_0 t[/itex]
C i'm almost clueless. i can sub the given expression into both of my derived equations for [itex]s_{min}[/itex] and [itex]s_{max}[/itex] and all i get is that they both equal [itex]2at(t-\tau)[/itex] which i can't see how to use to prove that [itex] s_{max}<s<s_{min}[/itex].
This is actually an intermediate mechanics question but seems simple enough.
Answers and Replies
mda
117
Substitute your values into the inequality for smax & smin.
Solve for v.
the implication needs to go the other way, if p is the statement about velocity and q is the statement about distance i need to prove p -> q, that would prove q->p
even if i did do as you said, how would i "solve" for v?
s > s_max or s < s_min
v*t > s_max or v*t < s_min
Since we are looking for the maximum initial speed, then
vo_max*t = vo_max^2/(2a) + vo_max*r
t = vo_max/(2a) + r
t - r = vo_max/(2a)
vo_max = 2a(t-r)
i don't understand what you've done
why did you equate the two?
Related Threads on Weird kinematics question
  • Last Post
E
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
