What is Fire? Exploring Heat & Light
  • Thread starter vorcil
  • Tags
    Fire
In summary, fire is a chemical reaction that occurs when a fuel source combines with oxygen and releases heat and light energy. It starts when a fuel source is heated to its ignition point and combines with oxygen in the air. During combustion, the fuel source's chemical bonds are broken, releasing energy in the form of heat and light. Fire is considered a plasma, the fourth state of matter, and can be dangerous due to its ability to spread quickly and produce toxic gases and smoke. It can also cause explosions if it reaches flammable materials or gases.
vorcil
398
I thought it might've been some kind of Ionized gas, hense the light and heat comming from it,
but I'm not too sure
http://www.youtube.com/watch?v=_2LpCdhuOyQ"
According to http://www-spof.gsfc.nasa.gov/Education/FAQs7.html#q97", we give the name "fire" to both a bunch of glowing matter particles and a plasma, which is a bunch of molecules that are so hot that the outer electrons have been knocked off and move around freely. Fire from a lighter is not conducting electricity, fire as seen from an electrical discharge is.
Fire is a chemical reaction that produces heat and light. It is typically created when a fuel source, such as wood or gasoline, combines with oxygen in the air and is ignited by a heat source. The heat from the initial reaction then sustains and propagates the fire, while the light is produced by the heated particles emitting energy in the form of visible light. The color of the light can vary depending on the chemical makeup of the fuel source. While fire can produce ionized gas, it is not the defining characteristic of fire. Understanding the science behind fire can help us better prevent and control it for our safety."
1. What is fire?
Fire is a chemical reaction known as combustion, in which a fuel source combines with oxygen and releases heat and light energy.
2. What causes fire to start?
Fire starts when a fuel source, such as wood or gasoline, is heated to its ignition point (the temperature at which it will begin to burn) and combines with oxygen in the air.
3. How does fire produce heat and light?
During combustion, the chemical bonds of the fuel source are broken, releasing energy in the form of heat and light. The heat causes nearby molecules to vibrate, producing more heat and sustaining the fire. The light is produced by excited electrons in the flames, emitting photons as they return to their ground state.
4. Is fire a solid, liquid, or gas?
Fire is considered a plasma, which is the fourth state of matter. It is created when a gas is heated to extremely high temperatures and becomes ionized, meaning that the atoms lose or gain electrons.
5. How can fire be dangerous?
Fire can be dangerous because it can spread quickly and easily, causing destruction and potentially harming living beings. It can also produce toxic gases and smoke, making it difficult to breathe. In addition, fire can cause explosions if it reaches flammable materials or gases.
  • Other Physics Topics
  • General Discussion
12K
  • Quantum Physics
