What actually is the centripetal acceleration formula?
In summary: F_r = -N\sin{\theta}## which comes from the fact that the force is perpendicular to the wire, so it has to be ##N## times the sine of the angle between ##N## and the horizontal.
Adesh
735
191
Is centripetal force the force acting towards the Center of rotation or towards the axis of the rotation?
Centripetal Acceleration ##a =
\frac{v^2}{r}##.
Centripetal force is defined as the force causing the body to follow a curved path, acting towards the center and always orthogonal to the direction of motion. For uniform circular motion the formula for centripetal acceleration is $$a_c = \frac{v^2}{r}$$.
But my understanding of centripetal acceleration began to shake when I confronted this problem:
A smooth wire of length ##2 \pi r## is bent into a circle and kept in a vertical plane. A bead can slide smoothly on the wire. When the circle is rotating with angular speed ##\omega## about the vertical diamteter ##AB##, as shown in figure, the bead is at rest with respect to the circular ring at position P as shown. Find the value of ##\omega ^2##..
I attempted to solve it this way: at point P there is gravitational acceleration ##a_g = - g ~\hat{j}##. Now, I thought for point P to be in static situation (w.r.t. to the circle) this downward acceleration must be cancelled.
But if centripetal acceleration’s direction of point P were to act horizontally from point towards AB then we won’t get ##a_g## cancelled. How about having a centripetal acceleration acting from P to the point O? In this way we surely going to get a vertical component of centripetal acceleration.
By some simple geometry:
We would get ## \theta = \frac{\pi}{6}##. Now, the vertical component of ##a_c## is ##a_c \cos \theta = \frac{v^2}{r} \frac{\sqrt 3}{2} = \frac{\sqrt 3 \omega^2 ~r}{2} ##. Now for equilibrium we must have $$ a_c \cos \theta = g \\
\frac{\sqrt 3~\omega^2 ~r}{2 } =g \\
\omega ^2 = \frac{2g}{\sqrt 3~r}$$.
Although, I have reached to the correct answer but I suspect the step when I said the centripetal acceleration would act from P towards O.
You're forgetting the normal force from the wire. For equilibrium the combined force of gravity and the normal force must equal the required centripetal force.
Likes etotheipi and Adesh
Normal force from what? Can you please draw it in my diagram which I have posted in my original post?
Whether the wire is spinning or not, there are two forces acting on the bead. If there were only gravity, then the bead would fall straight to the ground (as though the wire were not there). As the bead falls, the wire forces it to move in the shape of the wire. As there is no friction, this force must be normal to the curve of the wire.
There is no direct centripetal force in this problem. In equilibrium, the centripetal force is the sum of the other two forces: it's the total force in ##F = ma##.
If you can tolerate my crude artistic skills, this is a cross-section of the bead and wire frame, where the blue part is supposed to be the wire frame and the black part the bead. The red arrows are the contact forces.
For any angle other than ##\theta = 0## the normal force is going to have a horizontal component because the plane of contact between the wire and the bead will also no longer be horizontal wrt the lab.
Likes Adesh
Does normal force act towards the Center and when we resolve it the vertical component cancels the gravity and the horizontal component causes it to move along the curve of the wire?
If that is so, then how do we find the magnitude of the normal force ? And how the wire exerts the normal force, is it the two portions of wire on the sides P exert forces on it?
I think the blue part represents the bead and the black represents the wire.
The wire is a circle and the normal to a circle is colinear with the radius.
You find the forces the way you always do in an equilibrium problem: balancing forces using ##\vec F = m \vec a##.
Likes etotheipi
Diagram check :cool:
  • Love
Likes PeroK and Adesh
Adesh said:
How to get the magnitude of ##\mathbf N## ?
You don't really need the magnitude. The bead is at rest vertically so ##F_y = N\cos{\theta} - W = ma_y = 0##. Now choose a cylindrical coordinate system with the origin at the centre of rotation of the bead so that ##F_r = ma_r = -mr\omega^2##. You also know from the diagram that ##F_r = -N\sin{\theta}##. Now you have two equations and can eliminate ##N##.
etotheipi said:
You don't really need the magnitude. The bead is at rest vertically so ##F_y = N\cos{\theta} - W = ma_y = 0##. Now choose a polar coordinate system with the origin at the centre of rotation of the bead so that ##F_r = ma_r = -mr\omega^2##. You also know from the diagram that ##F_r = -N\sin{\theta}##. Now you have two equations and can eliminate ##N##.
I have a little confusion here: why ##F_{r}## is equal to ##m\omega^2 r##? Beacuse ##F_r## must go from origin O to the point P where the force is acting, hence according to me ##F_r = N##.
A cylindrical coordinate system would be more appropriate in 3D, I've edited my last post. But the same logic still stands, and we don't actually need to use the vertical coordinate (so it's essentially still polar).
I set the origin of this coordinate system at the centre of rotation of the bead. This is not the centre of the sphere traced out by the rotating wire frame!
Likes PeroK
Adesh said:
we won’t get ##a_g ## cancelled.
Further to @PeroK's point, the centripetal force would not "cancel" gravity anyway.
Centripetal force is not an applied force. In the present case, gravity and the restraining force from the wire are the applied forces. They have a resultant.
The centripetal force is, by definition, the component (of the resultant of all applied forces) which is normal to the velocity.
Oh my God! I never knew this, thank you so much for telling me that. This is what I have understood from your reply:
Centripetal force is just one of those components of the applied force which acts towards the center/axis of rotation, you cannot apply centripetal force, gravity can be applied, tension can be applied, normal force can be applied but not the centripetal force..
I have saved a screenshot of your reply , it was just amazing .
I’m still getting two problems:
1. From the diagram of @etotheipi (that blue ball and black rim diagram, where he made the mistake of calling the blue ball as the wire instead of the bead 😂) it was quite natural to imagine that normal force existed, but in real life the wire goes through the bead (there is a hole in the bead through which the wire goes) and I’m finding it very hard to imagine how normal force will be exerted in that case.
2. Why I got a right answer when I used ##\mathbf N## as ##m~\omega^2 r## ? Is the magnitude of ##\mathbf N## really the ##m\omega ^2 ~r##?
  • Skeptical
Likes etotheipi
An unfortunate mistake on my part :eek:
See post #5. Sorry for the colour change!
Can you show your work here? I'm not quite sure how you got this part.
It is in my original post.
On the bead, $$\mathbf{N} + m\mathbf{g} = m\mathbf{a} = -mr\omega^2 \mathbf{e}_r$$ $$(N\cos{\theta})\mathbf{e}_z - (N\sin{\theta}) \mathbf{e}_r -mg \mathbf{e}_z = -mr\omega^2 \mathbf{e}_r$$ Then it follows that ##N\sin{\theta} = mr\omega^{2}##.
N.B. I'm having a sort of internal crisis about whether to use ##\mathbf{v}## or ##\vec{v}##; the latter seems more natural but the former looks cooler...
Just out of interest, a charge moving with ##\mathbf{v} = v_x \mathbf{e}_x + v_y \mathbf{e}_y + v_z \mathbf{e}_z## in a uniform magnetic field ends up with a helical trajectory. If we let ##\mathbf{B} = B_x \mathbf{e}_x##, for instance, the force ##\mathbf{F} = -qv_z B_x \mathbf{e}_y - qv_y B_x \mathbf{e}_z## isn't perpendicular to ##\mathbf{v}##. I've always considered ##\mathbf{F}## in this context to be a centripetal force, but according to this definition it wouldn't be.
I wondered what you think? Thanks!
etotheipi said:
If we let B=BxexB=Bxex\mathbf{B} = B_x \mathbf{e}_x, the force F=−qvzBxey−qvyBxezF=−qvzBxey−qvyBxez\mathbf{F} = -qv_z B_x \mathbf{e}_y - qv_y B_x \mathbf{e}_z isn't perpendicular to v
It is indeed perpendicular to ##\mathbf v##. Take its dot product with ##\mathbf v## and you going to get zero.
Likes etotheipi
Ah, you're quite right. I put in a minus sign where it didn't belong! Should be ##\mathbf{F} = qv_z B_x \mathbf{e}_y - qv_y B_x \mathbf{e}_z##
Likes Adesh
I've deleted my post. If you've read it, forget it. o_O
What was wrong with it? I thought you were just showing that if ##\vec{r} = r\hat{r}##, then ##\vec{v} = \dot{r}\hat{r} + r\dot{\theta} \hat{\theta}## and ##\vec{a} = (\ddot{r} - r{\dot{\theta}}^2)\hat{r} + (r\ddot{\theta} + 2\dot{r}\dot{\theta})\hat{\theta}## by deriving and not ignoring the unit vectors?
I did not take into account that ##\vert \vec u\vert## might have a non linear function as its argument. :x
Likes etotheipi
etotheipi said:
deriving
french influence?
  • Haha
Likes Adesh
Slipped right past me too!
archaic said:
french influence?
My maths teacher tends to say 'derive' so I guess it just slipped into my vocabulary, derive something and then anti-derive it... I guess it should really be differentiate but why waste precious time on 3 more whole syllables o_O
  • Haha
  • Skeptical
Likes Adesh and archaic
Are you a conservative (of words)?
  • Haha
Likes etotheipi
@Adesh one other thing that might be useful is the concept of n-t coordinates. The unit vectors are body fixed and are oriented s.t. the normal unit vector ##\mathbf{e}_n## points toward the instantaneous centre of curvature and the tangential unit vector ##\mathbf{e}_t## points in the same direction as the velocity vector.
Since the centripetal force & centripetal accelerations are by definition those components orthogonal to the velocity, we know that ##\mathbf{a}_c = \frac{v^2}{\rho} \mathbf{e}_n## and by extension ##\mathbf{F}_c = m\frac{v^2}{\rho} \mathbf{e}_n##. In the case of planar circular anti-clockwise motion, this coordinate system has nearly the same unit vectors as a polar coordinate system (save for the direction of the normal/radial ones). Whilst if we now consider something like elliptical motion, the centripetal acceleration is no longer in the direction of the ##\mathbf{e}_{r}## unit vector but it is definitely still along the ##\mathbf{e}_n## unit vector direction by definition.
I guess I'd need to calculate the work I do around a closed path first in order to find out... one sec. let me just run around the garden and check.
  • Haha
1. What is the centripetal acceleration formula?
The centripetal acceleration formula is a mathematical equation used to calculate the acceleration of an object moving in a circular path. It is represented by the formula a = v²/r, where a is the centripetal acceleration, v is the velocity of the object, and r is the radius of the circular path.
2. How is the centripetal acceleration formula derived?
The centripetal acceleration formula is derived from Newton's second law of motion, which states that the net force acting on an object is equal to its mass multiplied by its acceleration. In the case of circular motion, the net force is provided by the centripetal force, which is equal to the mass of the object multiplied by its centripetal acceleration. By equating these two equations, we can derive the centripetal acceleration formula.
3. What is the difference between centripetal acceleration and tangential acceleration?
Centripetal acceleration is the acceleration towards the center of a circular path, while tangential acceleration is the acceleration along the tangent of the circular path. Centripetal acceleration is always perpendicular to the tangential acceleration and is responsible for keeping the object in its circular path.
4. How does the centripetal acceleration formula relate to real-life situations?
The centripetal acceleration formula is applicable in many real-life situations, such as the motion of a car around a curved road, the rotation of a Ferris wheel, or the orbit of a planet around the sun. It helps us understand the forces and accelerations involved in circular motion and can be used to calculate the necessary parameters for safe and efficient design of circular structures and vehicles.
5. Are there any limitations to the centripetal acceleration formula?
The centripetal acceleration formula assumes that the object is moving in a perfect circular path with a constant speed. In reality, this is often not the case, and the formula may not accurately represent the acceleration of the object. Additionally, it does not take into account other external forces that may affect the object's motion, such as friction or air resistance.
