What are dimensions?
pelastration
162
Almost everything what we are speaking about in physics, in math, in religion, ... is related to "dimensions". It's an essential concept.
Dimensions are although used in several ways creating thus confusion.
Do we have to create new definitions for the different use?
Webster:
Main Entry: 1di·men·sion
Function: noun
Etymology: Middle English, from Middle French, from Latin dimension-, dimensio, from dimetiri to measure out, from dis- + metiri to measure -- more at MEASURE
Date: 14th century
1 a (1) : measure in one direction; specifically : one of three coordinates determining a position in space or four coordinates determining a position in space and time (2) : one of a group of properties whose number is necessary and sufficient to determine uniquely each element of a system of usually mathematical entities (as an aggregate of points in real or abstract space) <the surface of a sphere has two dimensions>; also : a parameter or coordinate variable assigned to such a property <the three dimensions of momentum> (3) : the number of elements in a basis of a vector space b : the quality of spatial extension : MAGNITUDE, SIZE c : a lifelike or realistic quality d : the range over which or the degree to which something extends : SCOPE -- usually used in plural e : one of the elements or factors making up a complete personality or entity : ASPECT
2 obsolete : bodily form or proportions
3 : any of the fundamental units (as of mass, length, or time) on which a derived unit is based; also : the power of such a unit
4 : wood or stone cut to pieces of specified size
5 : a level of existence or consciousness
I want to invite you to read an article of Michio Kaku: HyperSpace : A Scientific Odyssey, that you can find (in link articles) on entering the http://www.mkaku.org, [Broken] : (quote)"To see how higher dimensions helps to unify the laws of nature, physicists use the mathematical device called "field theory.... In other words, by adding the fifth dimension, we have trivially unified light with gravity. In other words, light is now viewed as vibrations in the fifth dimension. In five dimensions, there is "enough room" to unify both gravity and light."
In math's and physics "dimensions" are just added like if we were God.
Then we try to explain interrelationships to explain concepts like the Calabi-Yau spaces.
But isn't this LAYERING?
Dimensions represent also our daily physical world (related to "perspective"). But there are a lot of questions, such as: are dimensions 'isolated'. Isolation seems logic since we are unable to observe higher dimensions.
But also does it make sense to call TIME a dimension? Isn't it adding apples to oranges? Isn't time a quality (progress) of the physical processes? Can't we explain space-time in another way?
Are we trapped in word games? Do we have to rephrase?
Answers and Replies
Iacchus32
2,313
What are dimensions? Boundaries, or limitations of that which is held "in context."
pelastration
162
Boundaries = thus isolated?
Limitations = thus till there is a point, a field, a line which blocks. Thus valid in a certain area = isolated field.
Isolation is in my opinion one of the essential concepts in cosmos next to interaction and movement.
Now: are dimensions inter-involved, intertwined, inter-crossing... or interacting?
Here we see already that the actual definitions are contradicting depending from math and the physical world. In math you can exclude but can you in (what we call) the physical world?
Iacchus32
2,313
So we should accept everything as a whole first, before we begin to make distinctions ... Right?
I think little children are very good at that, but little children are also naive. Now, if only we could remain as little children and still be able to differentiate? ...
Iacchus32
2,313
The Mystery Within
From the thread, https://www.physicsforums.com/showthread.php?s=&threadid=611"
The mystery is that which lies within. And yet the mystery is none other than the essence which gives rise to form. Whereas all mysteries are pretty much one and the same, in that they lead to the one true mystery, The Mystery of Life ...
wuliheron
2,135
Fractal geometry speaks to the need to redefine dimension just as QM speaks to the need to redefine logic. In both cases what has become evident is that broader definitions are more useful for specific purposes if not so useful in everyday life. As has historically been the case more often than not, when our abstractions become more convoluted we don't throw out the old and replace it with the new. Instead, we build the new upon the old and retain the use of both.
Essentially, there are two ways of going about this process of redefining dimension. We can attempt to modify the existing definitions, thus taking the semantic and logical route, or we work backwards from the physical evidence. Both of these routes have so far focused on contextual definitions which is exactly what your dictionary definition points out as well.
Notably, there are two basic contexts in the dictionary definition of the word: the personal and physical. As with QM, blurring the lines between these two contexts will provide a yet again more useful definition of the word. In fact, the word context itself is a merely another aspect of dimension and, thus, the dictionary definition is self-referential, self-contradictory, and Indeterminate.
Mr. Robin Parsons
1,256
The Kaku link doesn't work, did anyone else notice that?
pelastration
162
thanks
Try this: http://www.mkaku.org/articles/ [Broken]
pelastration
162
Thanks, will take a look in Fractal geometry.
Since I like to 'see' the mechanics the second way is more appealing.
All depends what we call physical evidence, since so much is perception (just look to all subjects in these forums).
For some of us (me included) reality is not just something you can put into a box, there is more. So the proof of evidence is on our side.
For others reality it just weight, length, numbers, ... .
Persons are of course part of the Physical.
A abstract formulation could be: "A Dimension is an area in overall balance in which at least one internal parameter has the ability to act."
Area: aspect of unity (isolated from other dimensions) within limits /boundary, relative self-sustaining.
In overall balance = interior unbalance stays possible.
Internal parameter can be: a value, a person, conscious, a sub-dimension, a point, ...
Ability to act: parameter can stay inherent, move, interact, travel, ... .
Just a try ...
drag
Mathematical concepts, what else ? :wink:
wuliheron
2,135
This is being contested today by neurologists and radical behaviorists in particular. Emotions and affect are critical to both the formation of logic and perception and provide a clear way to bridge the mind body dichotomy of traditional western sciences and philosophy. However, I believe you are correct that a great deal of work needs to be done in this area before it can scientifically applied to such abstract concepts as "dimensions".
This is precisely why a good definition of dimension must contain the personal as well as the geometric.
As well as the mental. No mind, no person.
Just a try ...
This is a pantheistic interpretation of dimension. A more mystical one would be paradoxical, indeterminate, etc. For a Panentheistic theory such as your own both are required. Therefore you could modify this definition considerably.
Exactly what a dimension is remains ambiguous, but useful mechanical tautological definitions can be created using examples in nature such as Relativity and Fractal geometry supply. Such are already being attempted, but other than that I don't know any details on the subject. A fractal discription of QM is also being attempted, but the math is horredously difficult even by the standards of String theory.
Essentially, Fractal Geometry asserts there is such a thing as a "fractional dimension" and how this might modify the axioms of geometry is the thing no one has figured out yet. Like a lot of holistic theories, the devil is in the details.
Iacchus32
2,313
Dimensions define the form, by which the essence is contained within.
pelastration
162
Thx Wu Li,
you are indeed a lateral thinker. ;-)
You know what I am going for.
You know. You remember.
My Tao is not intentional pantheistic but leads to there for those who want to find that.
My theory doesn't need dimensions. You know too.
But I want to analyze dimensions since it seems to be trap for a lot of people and to be intellectual satisfactory for others.
For those interested:
Fractal Geometry: A Simple Explanation
Where classical geometry deals with objects of integer dimensions, fractal geometry describes non-integer dimensions. Zero dimensional points, one dimensional lines and curves, two dimensional plane figures like squares and circles, and three dimensional solids such as cubes and spheres make up the world as we have previously understood it.
However, many natural phenomena are better described with a dimension part way between two whole numbers. So while a straight line has a dimension of one, a fractal curve will have a dimension between one and two depending on how much space it takes up as it twists and curves (Peterson, 1984). The more that flat fractal fills a plane, the closer it approaches two dimensions. Likewise, a "hilly fractal scene" will reach a dimension somewhere between two and three. So a fractal landscape made up of a large hill covered with tiny bumps would be close to the second dimension, while a rough surface composed of many medium-sized hills would be close to the third dimension (Peterson, 1984). http://archive.ncsa.uiuc.edu/Edu/Fractal/Fgeom.html [Broken]
But: Fractal geometry can not offer me the complexity and levels of freedom that are reached with only a few pelastrations.
In the pelastration concept a dimension is simply a layer with specific properties and position depending from the joined tubes. In this dimension all kinds of sub-dimensions may occur.
pelastration
162
Interesting articles on time , including: Is time the fourth dimension?
http://www.utm.edu/research/iep/t/time.htm#SPACETIME
(follow link supplement)
"Yes and no; it depends on what you are talking about. Time is the fourth dimension of spacetime, but time is not the fourth dimension of space, the space of places.
Mathematicians have a broader notion of the term 'space' than the average person; and in their sense a space need not consist of places, that is, geographical locations. Not paying attention to the two meanings of the term 'space' is the source of all the confusion about whether time is the fourth dimension. The mathematical space used by mathematical physicists to represent physical spacetime is four dimensional and in that space, the space of places is a 3-d sub-space and time is another 1-d sub-space. Minkowski was the first person to construct such a mathematical space, and he was the first person to call time the fourth dimension, because it was the fourth dimension of his abstract space for spacetime. But spacetime is represented mathematically as a space of events, not a space of ordinary geographical places such as the place where the sun is located and the place where London is located.
In any coordinate system on spacetime, it takes at least four independent numbers to determine a spacetime location. In any coordinate system on the space of places, it takes at least three. That's why spacetime is four dimensional but the space of places is three dimensional. Actually this 19th century definition of dimensionality, which is due to Bernhard Riemann, is not quite adequate because mathematicians have subsequently discovered how to assign each point on the plane to a point on the line without any two points on the plane being assigned to the same point on the line. The idea comes from Georg Cantor. Because of this one-to-one correspondence, the line and the plane have the same number of points. If so, then the line and plane must have the same dimensions according to the previous definition. To avoid this problem, the notion of dimensionality of a space has been given a new, but rather complex, definition."
wuliheron
2,135
Thx Wu Li,
As absurd as it may be in some respects, your theory is a physical theory and, thus, it must be framed within a Pantheistic, Panentheistic, or other paradyme compatable with science. For that purpose mysticism just won't do. :0)
Iacchus32
2,313
The Fourth Dimension?
If you have a three dimensional form that exists within space, as well as the space that the exists within the form, what does that make space, the fourth dimension? Or volume? (i.e., within the entirety of space itself as well as within the form). And why is the Greek letter dela, essentially an equilateral triangle, called "the fourth?" Is it referring to the space, or fourth dimension, inside the triangle?
The reason why I say this is because it takes the first three dimensions to define to the fourth, and hence the "volume within" (as well as without, which exists within the entirety of space itself).
pelastration
162
Wu,
I am in QM now, solving your paradoxes.
Essential to Q Leap is that on arrival of the system S (two pelastrated tubes = entangled = acting as wave) in resonance field of M (measuring divice) the M provokes de-pelastration (redraw by polarity or disharmony) of the transport tube and (free-ed) particle tube (still composed tube) becomes visible after new pelastration with M (absorbed = measured, but absorbed doesn't mean united, just joined). In P every quanta is the result of previous pelastrations each tube keeping it's properties till de-pelastrated to more basic components.
I think P-approach is a structural(?) theory, not a physical.
(do you know I invented already some new toys based on Pelastration, under patent already, and already prototypes ;-)). Can become the new POGS ... who want to invest?)
Making designs now for web.
This (draft) has potential. Just need to formulate it more detailed. But the P-mechanism can handle it.
Some related stuff (from http://plato.stanford.edu/entries/qt-measurement/):
Qoute: "The post measurement entangled state of S+M, SUM cifi (X)gi, is a "pure state", represented by a single Hilbert space vector. There are, however, other sorts of states in QM, namely "mixed states", represented not by single vectors but rather by so called density operators. It is characteristic of S being in a mixed state that, from the point of view of statistical distributions over possible results of measurements on S, S behaves as if, for some set of vectors {fi} and some set of numbers {pi} for which SUM pi = 1, there is probability pi that S is in the state fi, for i = 1,2,.... (Mathematically, such a state is represented by a so-called density operator, SUM pi |_fi><fi_|, where |_fi><fi_| is the projection operator onto the vector fi.[14]) Von Neumann proved that when S+M is in the entangled state SUM cifi (X)gi then S is in such a mixed state. In particular, S behaves as if there were probability |ci|2 of being in state fi, for i = 1,2...; similarly M is in a mixed state, behaving as if there were probability |ci|2 of being in state gi, for i = 1,2....(von Neumann 1955, 424)."
pelastration
162
Interesting questions, making me to ask: are dimensions relative to the observer.
In the previous article it is clear that time as D4 is intended and related to spacetime and not to our living space. (Quote: " ...But spacetime is represented mathematically as a space of events, not a space of ordinary geographical places such as the place where the sun is located and the place where London is located.")
Look to your own body. Our body has coordinates in our 3D world. We have our 24h time-appreciation. But inside our body you have a transport , electrical and energy system, etc with internal coordinates which have no real relationship with our "standard" 3D world. We even have only a partly idea how it works. There is a varity of completely different type of interactions and other time-frames. On the lowest level we find DNA storeing our essence. But they again are composed from lower building boxes till we sit on the particle level.
These level of existence are all related with each other but we can say that they have another dimensional relevance. On the level you are resonant with you have access. So our 3D world is as a whole a layered system where Delta's have Delta's have Delta's ... inside. = infolded.
Iacchus32
2,313
But space exists both within and without and the only thing that seperates it is "three dimensional" form. Therefore, what dimension is space?
pelastration
162
Maybe you have to reverse your statement to: ... and the only thing that JOINS us is "three dimensional" form.
It might make sense to see your body as a small universe (a separte universum with its own dimensional realities) inside a much larger universe (that we call earth and space).
Delta in Delta, ...
A condition to such approach is that our super-dimension must be isolated (to keep it's structure, internal interaction, specificities and internal dimensioning) versus the surrounding dimensions, but also must have the tools to interact (to get energy, air, etc ). Another aspect will be the consciousness. Awareness can be seen as a synergic energetic level (cooperation) between several acting layers resulting in the ability of observation. Thus observation of the surrounding as being DIFFERENT from the own unity (ME : being the collectivity of various interconnected dimensions). As observer you will have the possibility to act independent from the surrounding world and make choices. Even in conscuiosness there will be different levels such as intellectual operations, emotions, ... .
This make me say that the basic mechanisms in the universe are movement, isolation and interaction. These fundamental processes must be jointed.
wuliheron
2,135
Sorry, don't have any money to invest. By structural I suppose you mean metaphysical. Even a metaphysical theory fits within one of the general philosophical catagories.
pelastration
162
Essential is a mechanism or process that can be applied to analyze or explain physic and metaphysical events. It joins the two levels. Explains the joint between our human physical en spiritual energies and there separation. Also reincarnation. Shows how homeopathy works, etc.
But on metaphysical level it stays neutral. An Sich.
But as said before you can re-read the Vedanta and understand Brahman and Atman in another way.
In analyzing you will see that it goes much farther than yin/yang, but it confirms yin/yang.
many dimensions
i believe that there are many dimensions and that we have actually may visited some of them.
but to what i know, we may be in a dimension right now. the dimension of life.
pelastration
162
That's right.
It all depend of what spectacles we use.
There are some essentials:
like you said: The dimension of life,
but also the dimension of love, and the dimension of physicsforums.
I hope you're joking
The demension of love is a sensical idea. Love is HUMAN PERCEPTION based on chemical reactions. Therefore, it doesn't make sense for a demension to exist just because humans feel this sensation.
From a positivist point of view (the idea of demensions should be viewed in a mathematical sense), demensions are only mathematically based, not emotionally etc.
Does a demension consist of more than one thing that makes it a relatively higher demension?
love is not everything
love is not everything. it can also have a dark side. it is true that humans percieve it and it's in a diffrent way.
That dimension of what you're talking abouti s not in here. we belong there. it's a dimension of peace. where we came from and that's why we all have this 'love'.
pelastration
162
I agree that if we speak about a dimension of love it are emotional layers that are meant. But love happens to be a type of energy that exists. Can we call it a dimension?
If a new Theory of Everything comes, it must also included such vibrations also.
Wouldn't it be logic to speak then of dimensions in physics and metaphysics?
By the way the Webster Dictionary includes already the "dimension of consciousness".
Michio Kaku wrote (http://www.mkaku.org/articles/becoming-a-physicist.shtml [Broken] ) : "Einstein also said that behind every great theory there is a simple physical picture that even lay people can understand. In fact, he said, if a theory does not have a simple underlying picture, then the theory is probably worthless. The important thing is the physical picture; math is nothing but bookkeeping."
This last sentence puts some questions about the function of maths in physics. Mathematics maybe be thrilling for clever minds but that's not the whole world. The strongest power of freedom is to relativize ourselves because then we transcendent to ... a higher dimension.
Now do you think that elements in mathematics neither differ from definitions depending from the axioma's or abstract starting point. For example are the elements in the algebra of Boole dimensions or not?
This is the essence of this thread. In what ways can we appreciate 'dimensions' and do we have to re-phrase or extend because the confusion is too large.
Does a demension consist of more than one thing that makes it a relatively higher demension? [/B]
In maths it is of course just adding dimensions. (see higher thread)
In systems like Kabbal (Jewish system) there are 400 dimensions.
What is your answer to this question: What are the mathematical coordinates of ART in our 3D world? If I can't find these coordinates does it mean ART doesn't exists?
To Greeneagle: Nice ! Peace Man!
Mentat
3,918
Whoah, wait a minute. People here are using the term "dimension" in a totally incorrect manner. Life, love, experience, change, fases of life, etc (other such metaphysical concepts) are not dimensions. A dimension is a physical entity. It is a coordinate, by which one measures the position of any give object. That's all it is. Perhaps there is another word, to describe that which some of you are speaking of.
(Q)
147
Not true. Dimension can also mean the magnitude of something in a particular direction. In this context one can use dimension to talk about change, experience, life, etc.
Mentat
3,918
You are correct, however, this thread did not seem to be talking about that kind of "dimension". For example, if you look at the very first post, pelastration mentions Michio Kaku's book about hyperspacial dimensions, and asks if time should be considered a dimension. This obviously has reference to the physical type of dimension.
  • #31
(Q)
147
So, what is non-physical about magnitude?
  • #32
Mentat
3,918
Magnitude is not one of the physical dimensions, because it is not used to describe position or movement. That is what the physical dimensions (which compose spacetime) do.
  • #33
(Q)
147
Ah, the youth – forever ignorant in their defiance.
Velocity and acceleration are vectors; therefore they both have magnitude and direction.
  • #34
Mentat
3,918
Ah the aged - forever patronizing.
What does that have to do with anything. Velocity and acceleration are not dimensions. The have magnitude and direction, but they don't describe the position of an object. And they don't warp due to the presence of matter (as Relativity dictates about spacial and temporal dimensions).
  • #35
(Q)
147
Don’t try and squirm out of this by putting words in my mouth. I didn’t say velocity and acceleration are dimensions, did I?
Again, I didn’t say that either. You’re digging yourself deeper and deeper.
Bravo! You managed to have completely twisted my response out of proportion to suit your needs, yet have failed miserably because you really have no idea what you’re talking about.
Suggested for: What are dimensions?
  • Last Post
  • Last Post
