Unveiling the Mysteries of Gravity Waves: Origins and Properties Explained"
In summary: Yes, Einstein was quite confident in the energy conservation of gravity, even though it took him a while to accept the idea. In summary, gravity waves are oscillations in the space-time "medium." They are created when masses are accelerated and energy is lost in the form of gravitational radiation.
billy_boy_999
131
what are gravity waves? i am guessing that they are some kind of oscillations in the space-time "medium"?
but gravity waves are not the normal carrier of the gravitational force? otherwise, because its an oscillation, the force wouldn't fall off with the square of the distance. so what special circumstances create gravity waves? where do they come from?
Astronomy news on Phys.org
A simple explanation is that gravity waves are to gravity as electromagnetic waves are to the electrostatic columb force between charges. They are related, but separate. Accelerating charges can produce electromagnetic radiation, and accelerated masses can produce gravitational radiation.
You might also want to read the sci.physics.faq on gravitational radiation
here
Taylor and Wheeler give a really simple explanation of gravity waves and why they are predicted.
Imagine heavy balls falling towards each other (by their own gravitational attraction) connected by an ideal massless spring. In theory, the spring should then be able to push the balls apart to their starting position again after they collide. But, the spring discovers that it requires more energy to return them to their starting position.
The idea is if you take a time slice while the balls are moving towards each other and then away from each other you notice something ... they feel the attraction of where the other ball was an instant in the past, not where it currently is, due to the delay for the information of its position to reach the other ball. So as they fall towards each other, they experience a tiny bit less attraction than they "should" because they feel each other as being slightly farther away, and then as they move apart, they feel slightly more attraction then they should for the same reason.
This means that energy has magically disappeared from the system because of this time delay in communication between them (assuming that gravity information travels at less than or equal to C).
The idea is that gravity waves carry this energy away as ripples in the fabric of spacetime.
If you think about it an em wave if you like is where a vector field defined over space is 'changing', simalirly a gravitational wave is where a tensor field defined over space is 'changing'.
Good explanation, Gonzo, in fact it is quite excellent. Gravity waves are a fundamental prediction of GR. Einstein realized this, but was reluctant to accept it. He finally took the very bold step of predicting gravity waves because it was the only apparent solution that satisfied the energy conservancy required under GR. Detecting them would be yet another monumental testimony to the sheer brilliance and depth of GR. Go LISA!
Ya, just to comment on gonzo's explanation, so a slight amount gravitational energy (attraction) is lost in the creation of a gravity wave?
So, let's say a star forms, its gravitational attraction will be slightly smaller then...what amount of energy? I hope I've been clear...
No effect on gravitational attraction. A small amount of the kinetic energy of the accelerating/decelerating object is leaked out via gravity waves.
Actually, a little bit of energy has been dispersed in the radiation. This is sometimes expressed that the object's "gravitational mass" is less than its "baryonic mass". This can also be called a "loss" (actually a dispersal) of "binding energy". In the formation of most condensed objects i.e. stars, most of this binding energy escapes as electromagnetic radiation rather than gravitational radiation, except in cases such as inspiralling neutron stars or black holes. In these cases a significant amount of energy is released in the form of gravitational waves.
Hope that helps.
best.
Jim Graber
Are you sure, in GR conservation of energy is not strictly required.
I'm not sure of anything. It leads to poorly conceived wagers. But in cases such as decaying orbits, there is an energy loss [albeit small] that is inexplicable without gravitational waves.
I see now graviational waves conserve energy in the classical limit (gravaitaional waves don't actually have enrgy in some sense though, that is if you look at a small enoguh region of any part of a graviational wave and meausr eit's enrgy it will be zero), so I guess in order for conservation you need to pick a preferred frame and you'd also need asymnpotical flatness.
It still seems odd to me that Einstein would worry about energy conservation edited to add: when, for regions of space the law of enrgy conservation is ruled out as being generally covariant a priori and general covaraincy was one of Einstein's main motivations to formulate the theory of genarl relatiivty.
1. What are gravity waves and how are they produced?
Gravity waves are ripples in the fabric of spacetime caused by the acceleration of massive objects. They are produced when massive objects, such as black holes or neutron stars, accelerate and create disturbances in the fabric of spacetime.
2. How were gravity waves first detected?
Gravity waves were first indirectly detected through observations of the Hulse-Taylor binary system. The system consists of two neutron stars orbiting each other, and the gradual decrease in their orbit matched the predicted energy loss due to the emission of gravity waves.
3. What properties can be studied through gravity wave observations?
Gravity waves can provide information about the masses, spins, and distances of the objects that produce them. They can also reveal details about the events that create them, such as mergers of black holes or neutron stars.
4. How can gravity wave observations contribute to our understanding of the universe?
Gravity wave observations can provide a new way to study objects and events in the universe that are not visible through traditional methods, such as black holes and the early stages of the Big Bang. They can also help test and refine theories of gravity and the structure of spacetime.
5. What new technologies are being developed to improve gravity wave detection?
New technologies such as laser interferometers and space-based detectors are being developed to improve our ability to detect and study gravity waves. These technologies can increase our sensitivity to smaller and more distant events, allowing us to observe a wider range of objects and phenomena in the universe.
  • Astronomy and Astrophysics
  • Beyond the Standard Models
