What are the effects of changing the speed of alternator?
  1. Jan 25, 2017 #1
    <Mentor note: Moved from a technical forum, therefore no template.>
    consider a situation;
    case 1: there is an alternator say 5KVA, 1500rpm, 50Hz, 400V.
    If I run the generator's shaft at 1500rpm - it will have the capacity to produce 5KVA and generatted voltage will be 400V with 50Hz.
    case 2: if i run at 2000 rpm what will be effect on power, freq and voltage?
    case 3:if i run at 1000 rpm what will be effect on power, freq and voltage?
    can anyone help me out with above questions with explanations?
    thanks for your valuable answer
Draft saved Draft deleted
