What characterizes an acid as strong?
  • Thread starter Xishan
  • Tags
    Acid
In summary, there are ten strong acids and ten strong bases. The degree to which an acid or base ionizes is based primarily on bond strength.
Xishan
40
I've posted this question in another thread... didn't get the answer though
Why does a strong acid (or a base) ionizes to a higher extent? Is this extent of ionization the only criteria for characterizing an acid (or a base) as strong or weak. Is it the simple bond polarization phenomenon that causes the ionization?
Chemistry news on Phys.org
i'm not a tutor but i would guess its due to bond strength. probably wrong tho
Does hydrogen bonding have some effect on pH?
Its due to the 'regularity' of the acid molecule to dissociate into Oxonium ions. For example, Hydrogen fluride has only something like 10% - 20% of its molecules dissociating into oxonium ions, while a 'strong' acid such as hydrochloric acid will have 90 - 100% dissocition of its molecules into oxonium ions.
So, my question stands unanswered! Why does HCl dissociate to such a high extent and while HF to only a little extent?
Its because the H-F Bond is much stronger than the H-Cl bond.
Note: you asked why strong acids IONIZE to a higher extent, and technically, this has been answered.
It is due primarily to bond strength, and temp...water only has the ability to pull apart some acids, that is one reason why 'sensitive' reactions take place @ lower temps. The acids dissassociate less because the water only has a certain amount of strength to rip them apart in the first place.
Hmmm... OK! I admit, Bladibla, you are right. You've answered my question. I actually overlooked the first sentence of your reply. Thanks!
Can someone please name around ten strong acids, strong bases, weak acids and weak bases and give their respective %ionization?
I got it myself, not TEN though!
http://www.dbhs.wvusd.k12.ca.us/webdocs/AcidBase/Strong-Weak-AcidBase.html
http://www.members.aol.com/profchm/tcjc_ch15.html
I'll be back with more questions in future. Inshallah
1. What determines the strength of an acid?
The strength of an acid is determined by its ability to donate protons (H+) in a solution. The stronger the acid, the more easily it releases protons.
2. How is the strength of an acid measured?
The strength of an acid is measured by its acid dissociation constant (Ka). A higher Ka value indicates a stronger acid, while a lower Ka value indicates a weaker acid.
3. What makes an acid strong?
Acids are considered strong when they completely dissociate in water, meaning all of the acid molecules break apart and release protons. Strong acids also have a high Ka value.
4. What are some examples of strong acids?
Some common examples of strong acids include hydrochloric acid (HCl), sulfuric acid (H2SO4), and nitric acid (HNO3). These acids have high Ka values and completely dissociate in water.
5. Can an acid be both strong and weak?
No, an acid can only be classified as either strong or weak. A strong acid will completely dissociate in water, while a weak acid will only partially dissociate. However, the strength of an acid can vary depending on the concentration of the solution.
  • Chemistry
10K
