Could a Neutron Star's Color be Rayleigh-Jeans Blue?
Forestman
212
If a person could orbit close to a neutron star what color would it appear to be?
I have always imgained them to be blue, but this might be totally wrong. :uhh:
Astronomy news on Phys.org
As I understand it, at the surface of a neutron star, most light is emitted in the X-ray range. In the visible range, red is emitted at about the same as blue and the other colors, so it would appear white to human eyes.
Your human eyes and body should not orbit too closely, or else tidal effects will turn you into spaghetti.
Thanks gtring
spaghettification!
Most neutron star radiation we detect is in the x ray spectrum, implying they are fantastically hot. It is, however, unlikely much if any of this radiation is directly emitted by the neutron star. Black holes also 'emit' high energy radiation but obviously none of it is emitted by the black hole itself. It is the result of matter collisions in the process of being devoured by the black hole. Most neuton star radiation can probably be attributed to this same effect.
A couple of equations that you might find of interest (based on a static 2 sol mass NS with a radius of 12 km)-
Tidal force equation (m/s2/m)-
[tex]dg=\frac{2Gm}{r^3}dr[/tex]
The 'ouch' radius (which is derived from the tidal force equation)-
[tex]r=\sqrt[3]{\frac{2Gm}{dg}dr}[/tex]
based on tidal forces being equivalent to 1 Earth g from head to foot (dg=9.82, dr=2), you're getting into within a radius of ~4,800 km of a neutron star. Based on a maximum limit of dg=10 Earth g from head to foot, ~2,300 km (though by this point you've probably passed out).
Based on an orbit of 4,800 km, a neutron star with a 12 km radius would appear to be half the size of our sun as it appears to us from Earth (or equivalent to a 5 mm disk held at arms length- 2r/d, d=distance).Gravitational redshift-
[tex]z=\left(1-\frac{2M}{r}\right)^{-1/2}-1[/tex]
where r is the radius of the star, M is the gravitational radius (M=Gm/c2) and z is the fractional shift in the spectral wavelength
[tex]\lambda_o=(z\cdot \lambda_e)+\lambda_e[/tex]
where λo is the observed wavelength and λe is the emitted wavelength
as gtring has already stated, blue light (475 nm) emitted from the surface of the NS would appear red (667 nm)If the neutron star being approached was a http://en.wikipedia.org/wiki/Magnetar" to contend with.
Thanks stevebd1, and thanks for putting links to the magnetar and diamagnetism. That was awesome about that frog being levitated. I have learned so much since I have been on this site!
Violet.
Those who witnesses nuclear explosions described the color of explosion (millions K) as violet
stevbd1 put the math to the fire,, well done! I only object to the mass equivalence thing. Volume to mass ratio is not linear.
Hi Chronos
I assume your saying the star would appear smaller due to curved space (i.e. the coordinate radius of the star would be less than 12 km) or are you talking about something else?
Betcha the gammas get you first. :wink:
Good post...
" It has even been said that at a distance halfway to the moon, a magnetar could strip information from a credit card on Earth."
I've been wondering how they stole my Discover card info. :wink:
Mostly correct, stevebd1, neutron stars do not radiate to any appreciable extent. They do strip matter from any convenient source.
It's true that neutron stars don't radiate much, but that's because they are small. However, they are quite hot, which means they would be very bright if you got close enough to them.
Dmitry67 said:
Violet.
Interesting, I hadn't ever heard this. Do you have links to this observation?
I'm just curious since I never thought about this before. If you had a lump of neutrons the size of a baseball at room temperature, what would it look like? Black? Transparent? Metallic? I know that photons do interact with neutrons but I'm not sure what the macroscopic effect would be.
Neutrons are only bound together in a neutron star due to the massive gravity. The smallest neutron star predicted is ~1.35 sol mass so if you were to take a baseball size 'chunk' of neutron degenerate matter, it would fly apart in a burst of energy due to massive unconfined pressure (which is normally overcome by extreme gravity).
Slightly off topic but strange matter (which is a quark-gluon plasma type composed of up, down and strange quarks) on the other hand is theoretically more stable than nuclear matter (i.e. iron), http://arxiv.org/PS_cache/astro-ph/pdf/0407/0407155v2.pdf" (page 19, fig 11) so small pockets of strange matter might exist without the need for gravity (keeping in mind that 1 cm cubed of strange matter would weight anywhere upwards of 2 billion tonnes.
stevebd1 said:
Neutrons are only bound together in a neutron star due to the massive gravity. The smallest neutron star predicted is ~1.35 sol mass so if you were to take a baseball size 'chunk' of neutron degenerate matter, it would fly apart in a burst of energy due to massive unconfined pressure (which is normally overcome by extreme gravity). .
Free neutrons are radioactive, and have a half life of about 886 seconds. Unless phase space prevents it, they will turn into a proton + electron + neutrino. It is not clear that phase space would prevent this in a neutron star. So how long will a neutron star last?
Of course it is. Just because it's not clear to you doesn't mean it's not clear to anyone.
In a neutron star, you have available energy levels for about 10% as many electrons as you have neutrons. Once these fill up (and they are filled with original electrons from the star as soon as the neutron star forms) you can only add an electron by giving it enough energy to be in an unoccupied and high energy state. This additional energy kinematically blocks neutron decay, making such stars stable.
This [what vanadium noted] also leads to the deduction neutron stars have an iron crust. Degenerate matter is pretty weird stuff.
I'm a new member and I hope this is not too far off topic: Would frame dragging in any way alter the appearance of a NS? (visibility, color, etc.)
Frame dragging effects would be negligible at the surface of a neutron star.
Thx Chronos.
To take into account frame dragging, the redshift as observed from infinity would be-
[tex]\alpha=\frac{\rho}{\Sigma}\sqrt{\Delta}[/tex]
where
[tex]\rho=\sqrt{r^2+a^2 \cos^2\theta}[/tex]
[tex]\Sigma=\sqrt{(r^2+a^2)^2-a^2\Delta\ \sin^2\theta}[/tex]
[tex]\Delta= r^{2}+a^{2}-2Mr[/tex]
and M=Gm/c2, r in this case would be the radius of the neutron star (say approx 10-12km) and m is the mass (say 2-2.2 sol)
(Note: while for a black hole, [itex]a[/itex] can be anything up to [itex]a=M[/itex], for a spinning neutron star, the max is more likely around [itex]a=0.4M[/itex] otherwise shredding would occur)
[tex]z=1/\alpha -1[/tex]
which can be rewritten-
[tex]z=\Sigma\left(\rho\sqrt{\Delta}\right)^{-1}-1[/tex]
and as in post #6-
where λo is the observed wavelength and λe is the emitted wavelength.
Returning to the OP's question, let's consider blackbody colors, since these will be the colors of anything with a thermalized spectrum. To see what, check on sites like What color is a blackbody? - some pixel rgb values.
Anything above 6700 K will look bluish, and above 17500 K or so, the colors don't change much. I like to call the color in this limit "Rayleigh-Jeans blue", because one is seeing the Rayleigh-Jeans limit of the blackbody spectrum.
The hotter stars all look Rayleigh-Jeans blue, and all the temperature values and estimates I've found for pulsars are greater than 10,000 K, so they also will look Rayleigh-Jeans blue.
1. What is the color of a neutron star?
A neutron star does not have a visible color like objects on Earth. It appears as a bright point of light in the sky. However, if it were possible to see the surface of a neutron star up close, it would appear a dull grey or beige color due to the extreme temperatures and composition of the star.
2. Can neutron stars have different colors?
Neutron stars can have different colors depending on their temperature and composition. Older neutron stars may appear reddish due to their cooler temperatures, while younger neutron stars may appear bluish due to their higher temperatures.
3. Why are neutron stars not visible to the naked eye?
Neutron stars are incredibly small and dense, with a diameter of only around 12 miles. They also emit most of their light in the form of X-rays, which are not visible to the human eye. Therefore, they appear as just a point of light when viewed from Earth.
4. Do neutron stars emit any visible light?
Neutron stars do emit visible light, but it is very faint compared to the X-rays they emit. Most of the visible light they emit is in the form of ultraviolet and blue light, which can only be detected with specialized telescopes.
5. Can the color of a neutron star change?
The color of a neutron star can change over time as its temperature and composition change. For example, a neutron star that is actively absorbing matter from a companion star may appear brighter and bluer due to the increased heat and energy production. However, these changes are not visible to the naked eye and can only be detected through specialized instruments.
  • Astronomy and Astrophysics
