What is the function of this 6 volt timer and motor control circuit?
  • Thread starter lonely_nucleus
  • Tags
    Circuit
In summary, the 6 volt timer and motor control circuit is used to regulate the operation of a motor by controlling the voltage and timing of its power supply. It allows for precise and efficient control over the speed and duration of the motor's operation, making it an essential component in various electronic and mechanical systems. Additionally, the timer function allows for automation and scheduling of the motor's activation, further enhancing its functionality.
lonely_nucleus
108
I have found this circuit and I was wondering what it did. Does it control how long a motor is running?https://www.google.com/search?q=6+volt+timer+55+motor+control+circuit&safe=strict&biw=1607&bih=834&source=lnms&tbm=isch&sa=X&ved=0CAcQ_AUoAmoVChMI28KE9-KkyAIVkKWICh2bxQ23#imgrc=TVAXCdSBnuQRPM%3A
No attachment?? At least I can't find it.
No attachment
Which circuit? I can't see one.
This circuit allowed you to change the speed of a motor by using 555 as a PWM generator. The speed is changing from almost 0 RPM up to the maximum RPM the motor can run.
What browser are you using that you are able to see the attachment that the rest of us can't see ?
The Firefox, but in realty I switch to BB code. And now I can see this link
https://www.google.pl/search?q=6+vo...=HPoPVoT7CcfhywP1w77gDg#imgrc=TVAXCdSBnuQRPM:
And this circuit
http://www.next.gr/circuits/DC-motor-control-using-555-timer-circuit-l41280.html
Thanks. What is "BB code" ?
I have had this problem too, inserting some image:
Just this
https://www.physicsforums.com/attachments/proxy-png.89725/?temp_hash=8db6cd77134e9c196af8ceda17abd892
will be inserted. But if I edit my post, I can see the full image.
What does this circuit do?
This is a common question in the field of electrical engineering. The answer depends on the specific circuit in question, as each circuit is designed for a specific purpose. Some circuits may perform simple tasks such as turning on a light, while others may be more complex and have multiple functions.
Why is it important to know what a circuit does?
Understanding the purpose of a circuit is crucial in troubleshooting and repairing any issues that may arise. It also allows for the optimization and improvement of the circuit's performance.
How can I determine what a circuit does?
There are a few ways to determine the function of a circuit. One of the most common methods is to analyze the circuit's components and their connections. Another approach is to consult the circuit's schematic or documentation, if available.
Are there different types of circuits?
Yes, there are various types of circuits, such as analog, digital, and mixed-signal circuits. Each type serves a different purpose and operates in a unique way.
Can a circuit have multiple functions?
Yes, some circuits can have multiple functions. For example, a microcontroller can perform tasks such as analog-to-digital conversion, data processing, and communication, all within a single circuit.
  • Art, Music, History, and Linguistics
  • Mechanical Engineering
  • Electrical Engineering
  • Computing and Technology
  • Biology and Medical
  • Atomic and Condensed Matter
  • Classical Physics
