What do the letters in the solar sail equation denote?
  • B
  • Thread starter Enis
  • Tags
    Mean
In summary, the letters in the solar sail equation denote the following: F is the resultant force per square metre of the sail, F0 is the force per square metre of a hypothetical sail at 1AU and perpendicular to solar rays, θ is the angle between the direction towards the Sun and the direction perpendicular to the sail, and R is the distance to the Sun in units of AU. The force on the sail and the acceleration of the craft depend on the inverse square of the distance from the Sun and the square of the cosine of the angle between the sail force vector and the radial from the Sun. This cosine factor takes into account the angle of incidence of the solar rays hitting the sail, which affects the amount of force imparted
Enis
Specifically, what does each of the letters denote in this solar sail equation?
"The force on a sail and the actual acceleration of the craft vary by the inverse square of distance from the Sun (unless extremely close to the Sun[17]), and by the square of the cosine of the angle between the sail force vector and the radial from the Sun, so
F = F0 cos2 θ / R2 (ideal sail)
where R is distance from the Sun in AU. An actual square sail can be modeled as:
F = F0 (0.349 + 0.662 cos 2θ − 0.011 cos 4θ) / R2"
From Wikipedia.
Thanks in regards!
F is the resultant force per square metre of the sail, F0 is the force per square metre of a hypothetical sail at 1AU and perpendicular to solar rays. θ is the angle between the direction towards the Sun and the direction perpendicular to the sail (so 0° is face-on and 90° is edge-on). R is distance to the Sun in units of AU.
Even getting this equation from WIkipedia I think it would be a good idea to work it out manually one's self to both verify and understand what it means.
The part about the force being imparted to the whole sale being proportional to the distance away from the Sun is common sense and follow the inverse R^2 relationship of light energy from a point source. The part that might be throwing you though is where the cosine comes in. Now don't quote me on this (as I haven't read this carefully enough) but I think their point has to do with the angle of incidence of the rays of light hitting the sail.
Usage of cos(x) is the typical way of calculating the portion of 100% light that effectively hits the sail and is also used in the calculation of drag (looking at wind instead of photons but the same principle). Just draw out the geometry of it on paper and you'll see this is true remembering tan theta = Opposite/Adjacent (and its related identities, especially for cos).
1. What is an equation?
An equation is a mathematical statement that shows the relationship between two or more quantities. It typically includes variables, constants, and mathematical operations such as addition, subtraction, multiplication, and division.
2. How do you read an equation?
Equations are read from left to right, and the equal sign represents the balance between the two sides. The left side of the equation is known as the "left-hand side" or "LHS," while the right side is known as the "right-hand side" or "RHS." Variables are typically represented by letters, and their values can change depending on the equation.
3. What does the equal sign mean in an equation?
The equal sign in an equation means that the two sides are equivalent or balanced. This means that whatever is on the left side of the equal sign is equal to whatever is on the right side. In other words, both sides of the equation have the same value.
4. How do you solve an equation?
To solve an equation, you need to find the value of the variable(s) that make the equation true. This is done by using mathematical operations to isolate the variable on one side of the equation. The goal is to end up with the variable by itself on one side and the numerical value on the other side.
5. What does this specific equation mean?
The meaning of a specific equation depends on the context in which it is used. It is essential to understand the variables and constants in the equation and what they represent. For example, an equation in physics may represent a physical law, while an equation in chemistry may represent a chemical reaction. It is crucial to understand the application of the equation to fully understand its meaning.
  • Astronomy and Astrophysics
  • General Math
16K
17K
34K
