How Do Modifications in Microphysics Affect Inflationary Cosmology Predictions?
  • Thread starter wolram
  • Tags
    Paper
In summary, the researchers calculated the spectrum of density fluctuations in models of inflation using a weakly self-coupled scalar matter field and investigated the impact of modifications to the physics on length scales smaller than the Planck length. They found that for some dispersion relations, there were no changes to the predictions, but for others, significant differences were observed, including tilted spectra, exponential factors, and oscillations. This suggests that the predictions of inflationary cosmology in these models are not robust and can be affected by changes in super-Planck-scale physics. The researchers also noted a potential way to support or falsify different theories of microphysics.
wolram
Dearly Missed
4,446
558
We calculate the spectrum of density fluctuations in models of inflation based on a weakly self-coupled scalar matter field minimally coupled to gravity, and specifically investigate the dependence of the predictions on modifications of the physics on length scales smaller than the Planck length. These modifications are encoded in terms of modified dispersion relations. Whereas for some classes of dispersion relations the predictions are unchanged compared to the usual ones which are based on a linear dispersion relation, for other classes important differences are obtained, involving tilted spectra, spectra with exponential factors and with oscillations. We conclude that the predictions of inflationary cosmology in these models are not robust against changes in the super-Planck-scale physics.
Comment: 4 pages, 1 figure. One important correction in the Corley/Jacobson case with b_m>0 and some misprints corrected. To appear in Mod. Phys. Lett. A
http://citebase.eprints.org/cgi-bin/citations?id=oai:arXiv.org:astro-ph/0005432
Let's take it piece by piece:
The density of matter in the universe will fluctuate depending on the physics; the fluctuations will come at various frequencies and the strengths of the fluctuations at each frequency form the spectrum. This can be estimated from the observations of the CMB.
They introduce this simple field - it just has a magnitude, like a temperature, not any particle properties - as a surrogate for various microphysics theories (gravitons or quantum gravity theories).
Dispersion relations are the physicists' way to express things like scattering and refraction, typically of light, but also in this case the despersion of those density fluctuations, whose history we can estimate from the CMB data. By varying their field, they can represent different theories of gravity at the Planck scale, and calculate the resulting dispersion relations in each case.
And they claim to find a strong effect; some microphysics changes the dispersion relations so that the history of the fluctuations doesn't match what we observe. While this COULD be due to their approximation (that scalar field), it is clearly a suspicious behavior caused by different kinds of microphysics. Thus a possible way to support some of them and falsify others.
Thank you SA,
1. What is the main finding of this paper?
The main finding of this paper is the discovery or conclusion that the authors have reached after conducting their research and analysis. It is usually stated in the abstract and discussed in detail in the results and discussion sections.
2. What is the methodology used in this paper?
The methodology refers to the specific methods and techniques used by the authors to conduct their research. This could include experiments, surveys, data analysis, or other approaches. It is usually described in the methods section of the paper.
3. What is the significance of this paper?
The significance of a paper refers to the importance and relevance of the findings. It could be significant in terms of advancing scientific knowledge, addressing a gap in research, or having practical implications in a particular field.
4. What are the limitations of this paper?
The limitations of a paper refer to any factors that may have affected the accuracy or generalizability of the results. This could include sample size, methodology, or other constraints that may have influenced the findings.
5. How does this paper contribute to the existing body of knowledge?
This question aims to understand how the paper adds to the current understanding of a particular topic or field. It could be by providing new insights, confirming or contradicting previous research, or introducing a new perspective. This is usually discussed in the introduction and discussion sections of the paper.
  • Beyond the Standard Models
