What does this symbol mean?
  • Thread starter eax
eax
61
There is a symbol that looks like this http://mathworld.wolfram.com/nimg268.gif [Broken]
The symbol is like a line that is curved on both ends.
Thanks in advance!
Answers and Replies
The natural logarithm of x is equal to the integral of (1/t)dt from 1 to x.
eax
61
I don't think I'm going the right way with my problem. Anyway out of interest I want to know how to calculate the sin(x) without using the function(or cos, tan etc.) on the calculator.
Icebreaker
On the unit circle, there are places where sin(x) is defined exactly. Other than that, you could also use linear approximation, but that would require the derivative, and thus cosine.
A more precise way would be:
http://mathforum.org/library/drmath/view/64635.html
Integral
Staff Emeritus
63
Use a Taylors series.
[tex] \sin (x) = x - \frac {x^3} {3!} + \frac {x^5} {5 !}- \frac {x^7} {7!}+ ... [/tex]
The more terms you use the more accurate the result. This is the math behind small angle approximations. For small angles sin(x) ~ x.
x must be in radians.
Edited per Mathwonks correction.
OPPS!
HallsofIvy
41,847
969
I am told that calculators use the "Cordic" algorithm for things like sin, cos, log, exp.
Apparently it is faster than the Taylor's series. Here is a link to a website about it:
http://www.dspguru.com/info/faqs/cordic.htm
My father used to call the integral sign a "seahorse"!
Icebreaker
What exactly is the difference between an equal sign and an equivalence sign (as used in first post)?
selfAdjoint
Staff Emeritus
Dearly Missed
6,852
In the case of the OP's image, it means that the natural log is DEFINED by that integral. This is where ln, and e, and all come from, integrating the hyperbolic function 1/x.
mathwonk
11,312
1,527
in Integra's post there are sign errors, i.e. the signs should alternate, so the series given will not compute sin(x) at all.
eax
61
these are to get approximates What is the original sine formula?
dextercioby
Insights Author
13,194
764
What do you mean...?That formula converges for every argument and can definitely e put under a simpler form,using the summation symbol "sigma".
Daniel.
Zurtex
1,120
[tex]\text{Sine}(\theta) = \frac{\text{Opposite}}{\text{Hypotenuse}}[/tex]
chroot
Staff Emeritus
40
There's no such thing as an "original sine function." The sine function is transcendental, so it cannot be represented exactly in any algebraic form of finite length.
- Warren
dextercioby
Insights Author
13,194
764
Yes,Mathwonk,i'm sure everyone noticed that :wink:
Daniel.
eax
61
So then how was sine discovered? Is it possible to get sin(x) without using an infinite series equation?
dextercioby
Insights Author
13,194
764
You've been answered to the last question already.
As for the first,i can't trace it back earlier than Claudius Ptolemeu's tables on light refraction in water.
Daniel.
Sine tables were constructed empiricaly, to a decent number of significant digits, in the old days.
How is that for rigor!
dextercioby
Insights Author
13,194
764
And what is that supposed to mean...?You know,a little is always better than nothing...
Daniel.
mathwonk
11,312
1,527
One remark about defining sin, which may be obvious, is: if you look at the circle function definition, the sine function is the inverse of the circular arclength function.
i.e. the possibly more natural function is the function arcsin(y) taking y to the arclength along the circle from the point (1,0) where the circle meets the x axis, to the point on the circle at height y, for 0 <= y <= 1.
this function takes values from 0 to <pi>/2, and sin is its inverse on that interval.
this suggests the definition of sin as the inverse of the arclength integral
i.e. of the integral of dt/sqrt(1-t^2) from t=0 to t=x.
this is the analog of defining ln(x) as an integral, and then defining e^x as its inverse, or of defining an elliptic function as the inverse of the integral of dt/sqrt(1-t^4), as Euler did.
My opinion is it is natural to wonder how to express circular arclength as a function of some simpler parameter such as height, but rather less natural to ask about the sin function, its inverse.
BobG
223
84
Crosson's right. The sine and cosine were discovered empirically maybe as much as 3000 years before calculus, integration, Taylor, or McLaurin series were invented. They were simply using the concept of similar triangles. If the angles of one triangle were equal to that of a second, then the sides of both triangles must have the same proportions.
In fact, they eventually led to Euler's logarithmic functions. Trig tables were used for multiplication and division via your cosine/sine addition/subtraction identities for quite awhile before logarithms were ever invented. Napier drew from that and came up with base 10 logarithms, and Euler expanded on Napier's work to get the natural logarithms and e.
Related Threads on What does this symbol mean?
  • Last Post
  • Last Post
30K
  • Last Post
39K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
