What is Color: Exploring the Molecular Level
  • Thread starter Mephisto
  • Tags
    Color
In summary: Then the human eye has 4 receptors, 3 for Red, Green, and Blue, and one that senses brightness. It seems like it would be possible to specify any colour with only these 3 receptors, so why do we need the 4th one for pinpointing colours?In summary, the color of an object on the molecular level is determined by the frequencies of light that get reflected or absorbed. This depends on the properties of the material or atoms that make up the object. The human eye has 4 receptors, 3 for primary colors and 1 for brightness, which work together to give our vision a fallback position between full color and greyscale.
Mephisto
93
I don't think i clearly understand what color is on the molecular level... white light strikes a surface, and some of it gets reflected, and some gets absorbed, and you perceive the color based on what light gets reflected. That is ok, but what property of the material or the atoms that make it up exactly determines if light of frequency f gets reflected or absorbed?
Also, human eye has 4 rods, 3 for R G B, and 1 that apparently senses brightness. But can't you specify exactly every shade of color only using the 3 RGB components? Why do you need the 4th rod to pinpoint the color?
The second question is more of a biology question for fun, but mainly I am wondering about the first one.
thanks!
-meph
This is not really my area, but I thought it was something like this.
You should imagine that the electrons in a molecule have different orbitals, with different energies. Normally they are in the lowest orbital, but if you add enough energy to bridge the gap between two of them, they can go to a higher one (we call this an excited state). One way to add this energy would be to shoot in a photon with enough energy (which depends on the frequency through [itex]E = \hbar \nu[/itex]). Since the excited state is not a natural state, eventually the electron will fall back to its ground state and emit the energy difference between the excited state it was in and the ground state it's going to. This energy can be released in the form of a photon, which we perceive as reflected light. Or the energy could be lost (e.g. dissipated to the surroundings, used to excite another electron, etc) -- in fact the incoming photon may not excite an electron at all because it just doesn't have enough energy, and just lose its energy going through the molecule. Different atoms are sensitive to different energies (the energy needed to excite an electron differs, hence the frequency of the light you need to send in) and that's why different materials have different colors.
You're familiar with guitar strings (or the air in a hollow bottle) resonating with particular frequencies of sound. Comparably, the the electrons in particular molecules resonate with particular frequencies of electric field waves.
Regards rods, you've forgotten cones... read http://hyperphysics.phy-astr.gsu.edu/hbase/vision/rodcone.html" say.
You are looking at two separate issues here - the electromagnetic radiation itself (sometimes called radiometry), and the human response to that radiation (sometimes called photometry). Let's start with the radiometry first.
We can classify objects into two broad categories, emitters and non-emitters. The colour of an emitter depends on the spectrum of the electromagnetic radiation it emits (i.e. a "red" light is one that emits red frequencies). Non-emitters on the other hand have their colour characterised by their absorption spectrum. Frequencies that are NOT absorbed contribute toward the colour of that object, for example a "green" leaf absorbs red and blue but not green frequencies.
The colour of an emitter can depend on several things, depending on the nature of the emitter. Atomic sources, such as gas lamps and lasers have colours that depend upon atomic transitions. For example a mercury lamp will emit frequencies that correspond to allowed energy transitions (via E=hf). On the other hand, LEDs depend on the semiconductor bandgap, thermal (blackbody) sources depend on temperature etc. There is no universal parameter that determines the colour of an emitter.
The colour of a non-emitter depends on the what we call the band structure of the object, which is basically how the various energy bands of the solid are arranged. This is distinct from the atomic transitions mentioned above as they depend on the collective properties of a whole bunch of atoms and molecules, rather than individual atoms.
Okay, on to the photometry - you have 4 kinds of photodetectors in your eyes, rods and 3 types of cones, each sensitive to a different primary colour (red/blue/green). Rods are useful because the are more sensitive to light and are predominant in low-light levels (that's why it's hard to see colour when it's dark). Rods also comprise the bulk of our peripheral vision.
Claude.
The 3 types of cones respond to coloured light, and I won't try to expand on Claude's description, it seems clear enough. As with any detector it perforce has a higher threshold to ensure that when it triggers it gives an accurate or representative sample. You wouldn't want a green receptor going off for red by accident as it would throw off the point of the detector in the first place.
Rods on the other hand, primarily in the periphery of the retina handle low light conditions and respond far less to colour and more to light intensity.
Basically one handles colour and the other greyscale. Two separate systems that work together to give your vision a fallback position between full colour vision and blindness.
Zapperz has https://www.physicsforums.com/showpost.php?p=899393&postcount=4" :
Zapperz said:
Moral of the story: the properties of a solid that we are familiar with have more to do with the "collective" behavior of a large number of atoms interacting with each other. In most cases, these do not reflect the properties of the individual, isolated atoms.
AM
What is color?
Color is a visual sensation that is produced when light reflects off of an object and enters our eyes. It is a result of the different wavelengths of light being absorbed or reflected by objects, which is then interpreted by our brain as different colors.
How do we see color?
We see color through the process of light entering our eyes and being processed by specialized cells called cones. There are three types of cones in our eyes, each sensitive to different wavelengths of light. These cones work together to create the sensation of color.
What is the molecular level of color?
The molecular level of color refers to the chemical and physical properties of molecules that give objects their color. These properties include the ability to absorb or reflect specific wavelengths of light, as well as the arrangement of atoms within the molecule.
How do molecules affect color?
Molecules affect color by interacting with light in various ways. Some molecules absorb specific wavelengths of light, while others reflect them. The arrangement of atoms within a molecule can also affect the color it appears to our eyes.
Why do different objects have different colors?
Different objects have different colors because they are made up of different types of molecules. The molecular composition of an object determines which wavelengths of light it absorbs and reflects, resulting in the color that we see.
  • Other Physics Topics
  • Classical Physics
  • Electrical Engineering
  • Math Proof Training and Practice
  • Biology and Medical
