- #36
greypilgrim
- 508
- 36
Thank you! That clarifies a lot.
However, now I get the paradox I tried to construct in #15 with rotation-free boosts perpendicular to the force. I'm adapting your notation now:
Let a spring's work direction be ##x'##. It moves with ##v=0.9\cdot c## in ##y##-direction with respect to the lab frame ##I##. It has a spring constant of 1 N/m and its rest length is 1 m, but it's expanded to 2 m in ##x'##-direction. Hence a force gauge in the spring's rest frame ##I'## measures a restoring force of ##\vec{F}'=\vec{K}'=(1\,\textrm{N},0,0)^T## or ##K'=(0,1\,\textrm{N},0,0)^T##.
Now we boost to the lab frame. Since ##\vec{\beta}\perp\vec{K}'##, we get
$$K=\Lambda^{-1}K'=(0,\vec{K}')^T\enspace ,$$
hence ##\vec{K}=\vec{K}'##. So in the lab frame, the non-covariant three-force is ##\vec{F}=\frac{1}{\gamma}\vec{K}\approx (2.3\,\textrm{N},0,0)^T##.
So if we measure the restoring force of the moving, expanded spring in the lab frame, we find 2.3 N. Assume now we perform this measurement using an exact copy of the moving spring, i.e. spring constant 1 N/m and rest length 1 m. Then this spring will expand to 3.3 m, more than three times its rest length.
So the situation is asymmetric, the spring resting in the lab is longer. But why? Couldn't we have started with the lab spring, boost to the frame ##I'## and conclude that the other spring must be longer?
