What function does the sign wave represent in sound and light?
In summary, the use of sine waves in electronic and electromagnetic signals is based on the fact that the sine function can model all periodic functions and can represent the varying amplitude and polarity of these signals. This allows for a simple and efficient way to analyze and understand these complex signals. Furthermore, the use of sine waves to represent light and other electromagnetic waves is due to the periodic nature of these waves, which can also be described by sine functions.
Cyberice
50
I know that in electronics the sine-wave applies to AC voltage because it is constantly going from negative to positive, and back to negative again causing an analog wave of the rising and collapsing voltage and sometimes magnetic fields. But sound and light are supposed to create waves by just vibrating. You can't have a negative/positive vibration, and the medium in which it is traveling is not ionizing back and forth switching polarities to for a variation to be shown (which would need to be true for a sine wave to be formed). So why would they use a analog negative and positive wave to represent its function?
Science news on Phys.org
The sine function or sums of sins can be used to model all periododic functions. (Even square waves)
Consider the full sine expresion
F(t) = D0 + Asin( τ + t)
Here D0 is the offset
A is the amplitude
τ it the phase shift
t is the variable.
If D0 > A then the function will never be negitive. In electronis this could represent a AC ripple voltage riding on a DC potential.
Since light "waves" are periodic in nature they can be represented by sine waves. Look up information on Fourier Series to learn how ANY periodic function can be repersented as a sum of sine functions.
Integral's comments are good but I thought it might also help you to know that for light or radio waves the electric field grows to a maximum in one direction, decreases and then grows to a maximum in the opposite direction so in that sense there is a reversal of sign.
For example, in a vertically polarized light wave, the electric field is either pointing up or down as the wave comes toward you. The amplitude at one point in space over time is described by a sine function and the sign refers to whether it is pointing upwards or downwards.
1. What is a sign wave?
A sign wave is a type of waveform that represents a smooth, repetitive oscillation. It is characterized by a constant amplitude and frequency, and is often used to represent sound and light waves.
2. How does a sign wave represent sound and light?
A sign wave represents sound and light by graphing the changes in pressure or amplitude over time. In sound, the sign wave represents the changes in air pressure caused by the vibration of an object. In light, the sign wave represents the changes in the electric and magnetic fields as the light travels through space.
3. What is the function of a sign wave in sound and light?
The function of a sign wave in sound and light is to visually represent the amplitude and frequency of the wave. It allows us to see the pattern and shape of the wave, which can give us information about the properties of the sound or light wave.
4. How is the sign wave used in sound and light analysis?
The sign wave is used in sound and light analysis by measuring the amplitude and frequency of the wave. This information can then be used to analyze and study the properties of the sound or light, such as its intensity, pitch, and wavelength.
5. Are there any limitations to using the sign wave to represent sound and light?
Yes, there are limitations to using the sign wave to represent sound and light. While it is a useful tool for visualizing and analyzing waves, it does not take into account other factors such as phase, interference, and diffraction. Additionally, the sign wave is a simplified representation and may not accurately reflect the complexity of some sound and light waves.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
  • High Energy, Nuclear, Particle Physics
