What happens after Ionization
  • Thread starter sonurobots
I know that when a gas gets ionized it will conduct electricity but what will happen if we increase the voltage even after ionization?will it explode eventually?if it will explode will that be in nuclear label ?
Answers and Replies
SteamKing
Staff Emeritus
12,796
1,668
Why would an ionized gas explode?
PhysicoRaj
35
...when a gas gets ionized it will conduct electricity but what will happen if we increase the voltage even after ionization?
What happens if we increase the voltage applied to a conductor? It won't explode. You might be pointing at the rapid expansion of the plasma. But these will never be under the nuclear label. Ionisation is an electronic phenomenon. Not nuclear.
But after a certain voltage the conductor overheats ands burns .Then why won't the gas burn ?
200
The filament doesn't burn. It melts. Burning requires an oxidizer such as oxygen to be present
391
High enough voltage, in principle, can cause nuclear reactions, by accelerating fully ionised atoms (nuclei), which then collide with each other or the electrodes.
As regards burning, air consists of nitrogen and oxygen. They react at high temperatures (but not very high).
High enough voltage, in principle, can cause nuclear reactions.
How much high voltage is required ? how to calculate it?
391
Related Threads on What happens after Ionization
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
