What if field disappears?
I always have trouble understanding potential energy. Here's a realistic question which bothers me a lot.
Let's say I have a horse shoe electromagnet on a table. And I also have a permanent horse shoe magnet. I turn on the circuit(the electromagnet is functioning) And I bring the electromagnet and the permanent magnet closer to each other( I'm doing work because like poles are facing each other and repelling). Now the system seems to have some kind of energy because if I let go they will move apart with some velocity. But what if I turn off the electromagnetic? Will that energy disappear?
Answers and Replies
DaveC426913
2,613
No. It will be converted into kinetic energy. That energy could be harnessed to do work, such as denting your floor.
But how? If I turn off the electromagnet won't they stay where they are?
DaveC426913
2,613
I misunderstood. I thought you were supposing that turning off the electromagnet would cause them to "move apart with some velocity".
Rereading, I see what you're saying.
Yes sir. I'm sorry if I didn't write that correctly. My English is weak.
DaveC426913
2,613
Not at all. I was entirely my fault.
Do you have an answer to that question sir?
DaveC426913
2,613
I gotta think it through.
nasu
428
You don't need the top magnet to analyse the problem. The field of the electromagnet has some energy when it is powered.
When you turn off a coil the current does not just drop down to zero instantaneously. You just introduce a capacitor (the gap) in series with the coil. The current will oscillate back and forth. like in any LC oscillator. The energy will be dissipated eventually by resistive effects and radiation.
The time to dissipate may be quite short but it is there.
Is the energy stored in the field related to the work I did to bring the two magnets closer to each other? If I change the size of the permanent magnet or its strength and do the same experiment again. Will it store more energy this time?
nasu
428
Yes. Again, consider the case without battery. If you try to approach the coil with a magnet you will fill some repulsion, You will have to do some work to approach the magnet to the coil. This is due to the current induced in the coil, which current creates a field opposite to that of your magnet. The energy is stored in this current (or its field). This energy will be eventually dissipated into heat and maybe radiation.
In your case you have the two phenomena overlapped. You already have some current flowing and then induce some extra.
Got it. Thanks a lot. I'm very grateful to you for clearing this big confusion I had.
Khashishi
493
An electromagnetic is an inductor https://en.wikipedia.org/wiki/Inductor. The stored energy in an inductor is ##1/2 L I^2##. This stored energy is actually located in the magnetic field surrounding the inductor.
Likes Moazin Khatri
Related Threads on What if field disappears?
  • Last Post
  • Last Post
  • Last Post
