What is a Gaussian beam
8,264
Definition/Summary
A Gaussian beam is an electromagnetic wave, usually a laser beam, with a Gaussian cross-sectional irradiance pattern. The Gaussian irradiance profile results in minimal spreading due to diffraction effects.
The spot size [itex]w[/itex] represents the radius or half-width at which the irradiance is a factor of [itex]1/e^2[/itex] less than the central-axis irradiance.
Equations
For a Gaussian laser beam propagating along the z-axis, the electric field strength is a Gaussian function of the transverse (or radial) coordinate r:
[tex]E = E_0 \cdot e^{-r^2/w^2}[/tex]
where Eo and w are both functions of z.
It is common practice to work in terms of the irradiance, which is proportional to the square of the electric field, so that
[tex]I = I_0(z) \cdot e^{- 2 r^2 / w(z)^2}[/tex]
The various parameters of a Gaussian beam are related as follows:
[tex] \begin{align*}
\theta & = & & \frac{\lambda}{\pi \ w_o}
& = & & \sqrt{\frac{\lambda}{\pi \ z_R}} \
& = & & \ \frac{w_o}{z_R}
w_o & = & & \frac{\lambda}{\pi \ \theta}
& = & & \sqrt{\frac{\lambda \ z_R}{\pi}} \\ \\
z_R & = & & \frac{\pi \ w_o^2}{\lambda}
& = & & \frac{\lambda}{\pi \ \theta^2} \\ \\
b & = & & 2 \ z_R \\
\end{align*} [/tex]
Moreover,
w(z) & = & & w_o \sqrt{1 + \left(\frac{z}{z_R}\right)^2} \\ \\
R(z) & = & & z + z_R^2/z
\ = \ z \left[ 1 + \left( \frac{z_R}{z} \right) ^2 \right]
\end{align*} [/tex]
Extended explanation
Definitions of terms
(SI units for quantities are shown in parantheses)
b = confocal parameter (m)
E = electric field (V/m)
Eo = E at r=0
I, Io = irradiance (W/m2)
r = transverse or radial coordinate (m)
R(z) = radius of curvature of wavefronts (m)
w(z) = spot size (m)
wo = beam waist (m), or spot size at z=0
z = longitudinal coordinate (m)
zR = Rayleigh range
λ = wavelength (m)
θ = divergence half-angle​
Descriptive figure
* This entry is from our old Library feature, and was originally created by Redbelly98.
Answers and Replies
Related Threads on What is a Gaussian beam
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
