Exploring the Mysterious World of Photons
  • Thread starter yyttr2
  • Tags
    Photon
In summary, the conversation discusses the nature of photons and their properties, such as zero mass and rest energy. The question of whether photons are waves or particles is raised, along with the confusion surrounding their behavior when stopped or absorbed. The conversation also touches on electron orbits and the limitations of classical physics in understanding subatomic particles. It is recommended to seek further resources for a better understanding of these complex concepts.
yyttr2
46
I didnt know were to post this so it just goes here :).
(btw I'm in 9th grade so complexity is not an option.)
photons have zero mass, and zero rest energy.
are they a wave? or a particle?
If it has zero mass how can it be anything at all?
If its a particle, how can it exist without mass?
If there a wave...well, wtf is a wave without particles?
I have been studying chemistry and it is these questions, or ones similar to them that make me won't to stab something.
trying to understand atomic orbitals and electron configuration is easy. until you start trying to understand how N,L, and m changes the shapes,sizes, and orientation of orbitals.
and why m doesn't only change the orintation
i.e.
n3l2m0
is 2 balls with a ring around it but.
n3l2m1
is four balls.
I might be stupid and the answer be simple and easy but for the moment I am frustrated as hell!
forgive spelling errors
Science news on Phys.org
they're wave packets!
what? :cry:
it doesn't have zero mass, just zero rest mass
but...then, what happens if an photon stops moveing?...
it doesn't necessarily "stop moving". It can be absorbed by another particle like an electron, but it always travels at the speed of light.
faulty assertion
Surely when it gets absorbed it must decelerate.
how can a particle absorb another particle?...
Things I cannot visualize tend to confuse me.
Do not attempt to apply common sense or classical physics to the subatomic world. You are entering a realm where there is no analogy. You've got to accept the physics at face-value.
The best thing to do is to pick up a good book on the subject to flood yourself with the ideas. Frankly, the terse answers we can provide here will only serve to confuse you further.
But https://www.physicsforums.com/showpost.php?p=867751&postcount=3" that may get you started.
In a hydrogen atom, when an electron falls from a n=3, L=2 state to a n=2, L=1 state, the atom emits a small packet of visible light. It takes a few nanoseconds for the emission to take place, so this is the extent of the length of the wave packet (1 foot = 1 nanosecond, more or less). The packet contains energy and momentum, and always travels at the speed of light.
A photon is like a packet of energy. We describe it like a particle because that's the only way we can use it in a meaningful way in physics. Because a photon is energy, it can be absorbed by other particles.
A photon is the only thing that can travel at the speed of light, because it has no mass (you will learn later in Special Relativity that only objects that have no mass can actually travel at the speed of light. This is because the faster something goes, the heavier it becomes).
Hope that clears something up for you
Photon is not the only thing that can travel at the speed of light , the graviton can and maybe the Tachyon and maybe some others that i havn't listed.
No and no.
Gravitons have never been detected and are only theoretical at this point.
Tachyons cannot travel at the speed of light. They are massive particles (just like our electrons and protons), that travel FASTER than the speed of light, and cannot slow down TO the speed of light, or less than.
Additionally, tachyons are merely hypothetical particles. There's no reason to believe they exist at all, it's just that relativity doesn't explictly rule them out.
fine gravity waves travel at the speed of light , but y can't i believe in graviton's
the standard model has a very good track record.
I didn't say you couldn't, it's just that they have yet to be detected.
are u saying that the photon is the only thing that travels at the speed of light.
Mass and energy are two forms of the same thing. It just so happens that the a photon has no mass, but it's energy can be related to mass by E=mc^2 (Einstein's mass/energy relation).
Everything moves in waves (DeBrolie principle), although you cannot notice the waves of objects that we can see like a baseball.
The smaller a object is the larger the wave it makes when in motion. Visible light are photons and because they are so small, their waves are much bigger than a baseball's. In fact, you can see photon waves by shinning light through a pin-hole or small slit.
Trying reading Wikipedia under LIGHT and, separately, PHOTON...you'll pick up some interesting ideas.
In classical physics light is sometimes described as a "particle" or an electromagnetic wave and in quantum mechanics as a "quantum". You'll find we have decent mathematical models to describe how things like light behave, but are not so got at describing what they actually are.
Electron orbits, which you mention in your post, are also a simplified behaviorial description when in fact an electron is not really a particle...at least not all the time...
The point is nobody knows exactly what an electron or photon is...nor precisely how they got here...The only "simple" answers in physics are superficial...the real interesting ones are quite baffling!
good luck in your studies...
Well, even if we still haven't detected gluons, these are massless particles and so they travel at c.
gravity travels at c and I am pretty sure we have detected that.
DaveC426913 said:
No and no.
are u saying the gravity does not have an associated particle.
Nobody knows. It doesn't have to.
Qm says for every field there is an associated particle , you i mean we don't really know
, but we have a good idea that it does.
What if the whole idea of "Particle" is just man made macroscopic abstraction? Like how God was a man made idea and may be a false visualization? What if there are no such things as actual "particles"? What if there are just invisible globs of universal magic which sometimes can be created and destroyed (photons) but sometimes not (electrons)?
Rhetorical questions :-)
Why do people refer to photons traveling at all? I thought it was established that the photon is the quantized characteristic of an electromagnetic waves at the very instant some energy is emitted or absorbed. We only know of light having wave properties while it is traveling, and there is no evidence of quanta moving through space. At the exact moment of interaction -- photoelectric effect, Compton effect, etc. -- the energy and momentum transfer is quantized, and that's the photon. If this is known to be incorrect, please inform me -- thank you.
Because people were given the idea of "particles" by some arrogant scientist long ago and this generation of people needs to die out so that the next generation of people can avoid using particle analogies and think of the universe more like an invisible random magic.
1. What are photons?
Photons are particles of light that have no mass and travel at the speed of light. They are the fundamental units of electromagnetic radiation and carry energy and momentum.
2. How do we detect photons?
Photons are detected using specialized instruments such as photomultiplier tubes, photodiodes, and CCD cameras. These instruments are designed to convert the photons into an electrical signal that can be measured.
3. Can we see photons?
No, we cannot see individual photons with the naked eye. However, we can observe their effects, such as the color of an object or the brightness of a light source, when they interact with matter.
4. How are photons important in our daily lives?
Photons play a crucial role in our daily lives, from providing us with light and warmth from the sun to powering electronic devices such as smartphones and computers. They are also essential in medical imaging, communication technologies, and many other applications.
5. What is the mysterious world of photons?
The mysterious world of photons refers to the fascinating and complex properties of photons that scientists are still exploring and discovering. Despite being one of the most studied particles, there is still much to uncover about their behavior and interactions with matter.
  • Quantum Physics
  • Optics
  • Optics
  • Atomic and Condensed Matter
  • Astronomy and Astrophysics
