How Does an Additive Constant Impact Potential Energy Calculations?
  • Thread starter shanepitts
  • Tags
    Constant
In summary, the professor was teaching about potential energy and how to find the zero of it. He explained that you can add any constant onto the potential energy and that will give you an equally valid potential.
shanepitts
84
Pictured below was a problem shown in class with solution. I didn't have time to ask the professor a question about the last step involving an additive constant.
V is potential energy, re=Earth radius and z is distance from Earth's surface.
What is an additive constant, and how does it allow the last transformation?
You know (I hope) that the value of the potential energy depends on the reference point.
In the first formula, the reference point is at infinite. That means the energy becomes closer and closer to zero as z increases to infinite.
The other formula, U=mgz uses the surface of the Earth as reference.
So you need to change your formula to take this into account. Without the additive term, the energy at z=0 will be -mgR.
By adding +mgR you make the energy zero at z=0.
Likes shanepitts
An additive constant is a constant that you add on. A very typical example is when you do an indefinite integral.
##\int x dx = \frac{x^2}{2} + c ##
Here ##c## is an additive constant.
The zero of a potential can be defined where you like. This is because you only ever see differences in potential from one place to another. (Well... I guess strictly speaking that is not universally true. But for purposes of your homework assignment it is.) That means you can add any constant onto the potential and get an equally valid potential. All it does is redefine where the zero is. By using the form that your assignment has it has defined the zero of ##V(z)## to be at ##z=0## which seems a natural place to define it.
Likes shanepitts
Thank you for your detailed answer, I fully fathom now.
Thanks
What is an additive constant?
An additive constant is a numerical value that is added to a mathematical expression or formula. It does not have a variable attached to it and remains constant throughout the calculation.
Why are additive constants important in scientific research?
Additive constants are important because they allow scientists to account for factors that may affect their data or results. By including an additive constant, scientists can better control for variables and ensure the accuracy of their findings.
How is an additive constant different from a multiplicative constant?
An additive constant is added to a mathematical expression, while a multiplicative constant is multiplied to the expression. Additive constants affect the overall value of the expression, while multiplicative constants change the scale or proportion of the expression.
Can additive constants be negative?
Yes, additive constants can be positive or negative. A positive additive constant will increase the value of the expression, while a negative additive constant will decrease the value of the expression.
Are additive constants used in all scientific fields?
Yes, additive constants are used in many scientific fields, including physics, chemistry, biology, and mathematics. They are especially common in statistical analysis and data interpretation.
  • Classical Physics
  • Astronomy and Astrophysics
