What is Colour (in terms of Quarks)?
In summary, colour is simply a way of saying there are three possibilities for a property. It is analogous to electric charge, which has two possibilities.
FeDeX_LaTeX
Hello;
What is colour? Is it like the charge between quarks? I can't conceptually understand it, probably because of the wording.
Thanks.
Colo(u)r has no deeper meaning than simply a way of saying there are three possibilities for this property. In that sense it is analogous to charge, which has two possibilities.
How could they have discovered that quarks possesses a colour and an anti-colour? So, one side of the quark has 1 colour, the other side has another?
No, there's red and anti-red, blue and anti-blue, magenta and anti-magenta, and so on.
One quark has one colour.
(but a meson, for example, is made of two quarks, which can be a red quark and an anti-red quark)
You can think of red as being positive red charge, and anti-red as being negative red charge.
As others have pointed out, color is the "charge" of the strong interactions, and is largely analogous to electric charge. On a superficial level, that's all you probably need to know, but it may be useful to note that the symmetry structure is a little more complicated. The analogy with electric charge makes it easy to see how a quark and an anti-quark could combine into an overall color-neutral configuration.
But you can also combine three quarks together into an overall neutral configuration, which is harder to understand if you're used to just adding together positive and negative electric charges to find the total electric charge. I believe this is where the "color" term comes from, since it's reminiscent of combining red, green, and blue light to get white light. The color analogy is also a pretty loose analogy, though, so don't get too hung up on the term "color".
And yes, a quark has a single color label that can take on three values. Similarly with an anti-quark. A gluon, on the other hand, is usually written with two color labels that can take on 8 different combinations. To fully understand how it all works you would have learn about irreducible representations of SU(3), although suffice to say it's a bit more complicated than electric charge.
Oh, and I think the correct Wikipedia entry would be this, which is probably a good place to start reading:
http://en.wikipedia.org/wiki/Color_charge
This not quite accurate. Quarks and anti-quarks are matter and antimatter. For mesons to be color neutral they need an quark and and anti-quark of the same color.
Hi mathman! :smile:
Isn't that what I said? :confused:
1. What is colour in terms of quarks?
Colour is a physical property of quarks that describes the strong nuclear force between them. It is not related to the visual perception of colour, but rather a way to classify the different types of quarks.
2. How many colours are there in terms of quarks?
There are three colours in terms of quarks: red, green, and blue. These colours are used to describe the three types of quarks: up, down, and strange.
3. How does colour affect the behavior of quarks?
The colour of a quark determines how it interacts with other quarks through the strong nuclear force. Quarks with different colours can attract or repel each other, while those with the same colour cannot interact.
4. Can we see the colours of quarks?
No, the colours of quarks cannot be seen by the naked eye or through any type of imaging technology. They are purely a theoretical concept used to explain the behavior of subatomic particles.
5. Why are quarks called "colours"?
The term "colour" was chosen by physicists as an analogy to the mixing of primary colors in art and light. Just as red, green, and blue can be combined to create different colors, quarks with different colours can combine to form different types of particles.
  • High Energy, Nuclear, Particle Physics
  • Other Physics Topics
25K
  • General Math
