Combustion of NH4NO3: What is Needed and How it Reacts
  • Thread starter Soley101
  • Tags
    Combustion
In summary, combustion is a chemical reaction that produces heat and light when a material reacts with oxygen. It is also known as oxidation and is often accompanied by the release of smoke. In order to determine if a reaction is indeed combustion, one should look for the presence of oxygen and the production of heat and light. According to one definition, combustion is a type of chemical change that involves oxidation and the release of energy in the form of heat and light.
Soley101
37
what is needed for combustion?
I have this experiment NH4NO3 reacts to form (with chlorine as catalyst) N2O and water
the experiment is called oxidation of zinc, so another equation is Zn and NH4NO3 react to form ZnO and water. Anyways, the result is a blue flame and smoke
Combustion is the production of heat and light when something reacts with oxygen. I know that all combustion reactions are automatically oxidation reduction reactions. But how do i determine if oxygen is being used in this reaction to fuel the flame. Basically, is theis a redox and combustion reaction.
How Do I Know If This Is Indeed Combustion?
Combustion usually refers to oxidation, particularly the exothermic reaction of a material with oxygen.
One definition -
A chemical change, especially oxidation, accompanied by the production of heat and light.
http://www.answers.com/topic/combustion?cat=health
It's difficult to find a more reliable site that actually provides clear definition of "combustion".
1. What is the purpose of studying the combustion of NH4NO3?
The study of combustion of NH4NO3 is important for understanding the chemical reactions that occur when this compound is heated. It is also crucial for developing safety protocols and guidelines for handling and storing NH4NO3, which is commonly used in fertilizers and explosives.
2. What is needed for the combustion of NH4NO3 to occur?
In order for the combustion of NH4NO3 to occur, three things are needed: heat, fuel, and oxygen. The heat is usually provided through an external source, such as a flame, and the fuel is the NH4NO3 itself. Oxygen is present in the air and is necessary for the chemical reaction to take place.
3. How does NH4NO3 react during combustion?
When NH4NO3 is heated and reaches its melting point, it decomposes into two gases: water vapor and nitrous oxide (N2O). The water vapor helps to sustain the reaction by reacting with the remaining solid NH4NO3, which releases more oxygen and continues the combustion process.
4. What are the products of the combustion of NH4NO3?
The main products of the combustion of NH4NO3 are water vapor and nitrous oxide gas. In addition, small amounts of nitrogen gas and oxygen gas may also be produced. The exact composition of the products can vary depending on the conditions of the combustion reaction.
5. Are there any safety precautions to consider when working with NH4NO3?
Yes, there are several safety precautions to consider when working with NH4NO3. This compound is highly reactive and can be explosive in certain conditions, so it is important to handle it with care and follow proper safety protocols. This includes wearing protective gear, storing it in a cool and dry place, and avoiding contact with other chemicals that may react with NH4NO3.
  • Mechanical Engineering
  • Chemistry
16K
  • Materials and Chemical Engineering
