What is degree of order?
  1. Aug 17, 2008 #1
    Hi
    can i say that 100 lines in the same direction represents a higher degree of order then
    10 lines in the same direction?
    if not then what is the best example?
    thanks.
  3. Aug 17, 2008 #2
    tiny-tim
    Hi eranb2;1838295! :smile:
    Is this a thermodynamics/entropy question? :confused:
    Or is it just a general "order of magnitude" question?
    If the latter, how about $100 is a higher order of expenditure than $10?
    If the former, "100 lines in the same direction" isn't just a higher degree of order … it's totally ordered!! :biggrin:
    can't you think up an example that's less extreme (and physical rather than geometrical)? :wink:
  4. Aug 17, 2008 #3
    You definitely can say that 100 lines in a row represents an increase in order over 10 lines in a row. More energy needs to be invested to put the 100 lines in a row than it does to put just 10 in a row and that is one way to see this.
  5. Aug 18, 2008 #4
    Andy Resnick
    Education Advisor
    It's not clear what you (the OP) means by "higher degree of order". The order parameter, from field theory, has a clear meaning- it is zero in a symmetric phase and non-zero otherwise. There's ways to assess the regularity of "sort of" periodic functions by looking at the Fourier transform- arrays of lines can be represented fairly simply, and given the same line-line spacing, 100 lines require a larger envelope than 10; in Fourier space, the first function will cover a smaller spectral range, with an interpretation that it more closely approximates a truely periodic function.
    Another way to think of the situation is for a diffraction grating- a grating with 100 rulings will diffract more efficiently than a grating of 10 rulings; this can be a measure of order as well, I suppose.
    Can you be a little more specific by what you mean?
  6. Aug 19, 2008 #5
    Hi
    I read david bohm's book about order and creativity and was thinking.
  7. Aug 31, 2008 #6
    Doc Al
    Staff: Mentor
