Negative Energy in Particles: A Conundrum
In summary, the concept of energy can be confusing because it is arbitrary up to a constant and dependent on the frame of reference. This does not make it any less real, as it is a conserved property of objects. It is useful for calculating trajectories and is defined by convention as zero at the border between bound and unbound systems. However, it is important to note that energy is not just a book-keeping device and it requires energy expenditure to switch frames and measure energy in different frames.
GravitatisVis
I'm kind of struggling with the concept of energy. A particle in a conservative field has kinetic and potential energy (E=T+U), but I can always choose an inertial frame where the motion of the particle is zero, which means I can change the the particle's kinetic energy by just switching frames. I can Simultaneously change the zero point of the potential energy arbitrarily. So In one inertial frame the particle has E>0, in another E=0, and still E<0 elsewhere. I used to think that a negative total energy meant that the particle was in a bound state and vice versa, but now I'm not sure sure. Is it more of a bookeeping device for ultimately calculating the trajectory of the particle? Whats going on?
Great question. Energy is (generally*) arbitrary up to a constant---which is reference frame dependent, as you point out. Differences in energy are reference frame independent (i.e. invariant).
Generally the arbitrary constant is defined such that E=0 corresponds to the border between a bound and unbound system----e.g. a projectile escaping a planet. This is convention, and is useful only as much as it is used consistently.
*Always for practical purposes---but technically there are situations in quantum mechanics and field theories where I think it might be less arbitrary...
No, energy is very real. It is more than a book-keeping device. Just because a property changes value depending on which frame of reference you choose does not make it any less real. It just has to change in the right way when you switch frames (Lorentz transform between inertial frames. For instance, the speed of a baseball will depend on which frame you choose to measure it in. This does not make the speed an unreal property, the ball is obviously moving in all frames except its rest frame. So then you may ask, what is its real speed. The while point of Einstein's relativity is that there is no single real speed - there is no preferred frame. Everything depends on how you measure it. Likewise, there is no single real energy of an object (the rest energy is helpful). But this does not make it any less real.
Perhaps your problem is that mentally it is very easy to switch frames, and yet the energy of the observed object changes upon frame change, so you feel like you are creating energy out of nothing. But the object has not actually gained any energy, its just being measured differently because you are in a different frame. If you were to actually make a measurement in practice (say the kinetic energy of an asteroid), then change frames and retake the measurement, you would have to expend energy to accelerate your spaceship lab.
Thank you for sharing your thoughts and concerns about negative energy in particles. This is indeed a conundrum that has puzzled scientists for a long time.
First, let's clarify the concept of energy in particles. Energy is a fundamental property of particles that allows them to do work and produce change. In the case of a particle in a conservative field, as you mentioned, the total energy can be broken down into kinetic and potential energy. Kinetic energy is the energy of motion, while potential energy is the energy associated with the position of the particle in the field.
Now, let's address your concern about switching frames and the resulting change in the particle's energy. It is true that in different inertial frames, the particle's kinetic energy may appear to be different. However, this is simply a result of the relative motion between the frames and does not change the actual energy of the particle. The same applies to the potential energy - changing the zero point of the potential energy in different frames does not change the actual energy of the particle.
So, what does a negative total energy mean for a particle? It is not just a bookkeeping device, as it has important implications for the behavior of the particle. In classical mechanics, a negative total energy indicates that the particle is in a bound state, meaning it is confined to a specific region in the field. This is because the particle does not have enough energy to escape the potential well created by the field. On the other hand, a positive total energy would mean that the particle is in an unbound state and can escape the potential well.
In quantum mechanics, the concept of negative energy is more complex and is related to the phenomenon of antimatter. In this context, a particle with negative energy would be considered an antiparticle, with properties that are opposite to those of a regular particle.
In conclusion, negative energy in particles is not just a mathematical quirk, but a fundamental concept that has important implications for the behavior of the particle. It is not just a bookkeeping device, but a crucial component in understanding the dynamics of particles in a conservative field. I hope this helps clarify the concept for you.
1. What is negative energy in particles?
Negative energy in particles refers to the concept in quantum mechanics that particles can have a negative energy value. This means that the particles have less energy than they would have if they were at rest.
2. How is negative energy in particles measured?
Negative energy in particles is measured using a mathematical equation known as the energy-momentum relation. This equation takes into account the mass and velocity of the particles to determine their energy values, including negative energy.
3. What is the significance of negative energy in particles?
The significance of negative energy in particles is still a topic of debate and research in the scientific community. Some theories suggest that negative energy particles could be used in technologies such as quantum computing, while others propose that they may have a role in explaining the expansion of the universe.
4. Can negative energy in particles be observed or detected?
Currently, there is no direct way to observe or detect negative energy in particles. However, scientists have been able to indirectly observe its effects through experiments and calculations. Further research is needed to develop techniques for directly observing negative energy particles.
5. How does negative energy in particles relate to the concept of antimatter?
Negative energy in particles is not the same as antimatter. Antimatter particles have the same mass as their matter counterparts but have opposite charges. Negative energy particles, on the other hand, have less energy than their rest energy value. However, some theories suggest that negative energy particles could be a form of antimatter.
  • Classical Physics
  • Classical Physics
  • Classical Physics
