What is gravitating ?
  • Thread starter Mentz114
Mentz114
5,432
292
There is a static spherically symmetric perfect fluid solution of the EFE where the energy-momentum tensor is ##diag(\rho,p,p,p)## with ##\rho=b\,\left( 2\,b\,{r}^{2}+3\,a\right) /{\left( 2\,b\,{r}^{2}+a\right) }^{2}## and ##p={b}/({2\,b\,{r}^{2}+a})##. a and b are parameters with b>0 and 0<a<1. On the surface ##r=\sqrt{(1-a)/(2b)}\equiv r_{max}## the PF metric coincides with the Schwarzschild exterior, as long as the Schwarzschild parameter m has the value ##m_s= {\sqrt{1-a}\,\left( 1-a\right) }/( {4\,\sqrt{2b}})##.
Calculating ##M_s## the mass/energy total of the PF
[tex]\begin{align*}
M_s &=\ 4\pi\int_0^{r_{max}} r^2\rho\ dr = 4\pi\left[ \frac{\,b\,{r}^{3}}{2\,b\,{r}^{2}+a} \right]_0^{r_{max}}\\
&= \frac{\sqrt{2}\,\pi\,\sqrt{1-a}\,\left( 1-a\right) }{\sqrt{b}}\\
&= 8\pi\ m_s
\end{align*}
[/tex]
This seems most satisfactory but raises the question - what happened to the pressure terms in the EMT ? It appears that the integral of the energy density accounts for all the exterior vacuum curvature. Is this an anomaly or am I right to be surprised ?
(Actually I was very glad when the integral turned out like this - until the question of the pressure appeared).
Answers and Replies
16,173
Heuristically, the positive contribution of the pressure to the mass is exactly canceled by the negative contribution of gravitational binding energy to the mass. The easiest way I know of to see how that works is to look at the Komar mass integral, in which ##\rho + 3 p## appears in the integrand, but also the "redshift factor" ##\sqrt{1 - 2m(r) / r}## appears, and the two contributions cancel each other when the integral is computed over the entire volume of the object.
Mentz114
5,432
292
Thanks. That could account for it. I'll check out the KM integral.
This PF is more realistic than I first thought because the radius of the ball can be set to any multiple of 2m by a suitable choice of parameter a. As a-> 0 so rmax -> 4m, and as a->1 so rmax increases without bound.
Suggested for: What is gravitating ?
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
