Understanding Momentum in Quantum Mechanics: Explained Simply
In summary: WHOLE. It's like if you have a set of balls in a box and you want to know the TOTAL number of balls in the box, you can't just take a single ball out and count it. You have to take the balls out of the box, count them, and put them back in the box. This is analogous to the uncertainty principle in quantum mechanics- you can only measure a particle's momentum in ONE specific direction (the momentum vector is always perpendicular to the direction of observation), and the more you measure it in that direction, the more precise your measurement becomes. Also, the usual qualitative way of describing uncertainty, (that
StatusX
2,570
I know quantum mechanics is strange, but I'd like to think the strangeness is well defined. So can someone explain exactly what we mean when we talk about the momentum of a quantum particle? The reason I'm confused is that when the particle is in a position eigenstate, it has a definite position. If you take the measurement now, get a value, and then take it again later without disturbing the system in between, you'll get the same value. By Heisenbergs principle, the uncertainty in momentum is infinite. But how can it be that there is any uncertainty in momentum when the particle is sitting perfectly still at the same spot? It's not moving, so what is this momentum it might have?
Also, the usual qualitative way of describing uncertainty, (that you need to shine a very energetic photon to get an accurate position measurement, but that disturbs momentum, etc.) doesn't seem to make sense, because how can you disturb momentum but still maintain a fixed position?
I know I must be thinking about momentum the wrong way, ie, too classically. Because mathematically, position and momentum are completely symmetrical in QM, but intuitively, momentum tells how the position is changing, but position is irrelevant to the momentum.
Sorry I have never hear of a "position eigenstate."
What system is this true in? I don’t think it will be sitting perfectly still after measurement. How could you take a measurement and not impart some momentum to it? In what situation do you find a particle sitting perfectly still?
It will not maintain a fixed position and never had a fixed position.
If you have solved the SE of a particular system in position space you can transfer it to momentum space. Qualitatively it is like performing a Fourier transform.
Some if you have a Gaussian represent the probability function of some particle you find that a narrow position will result in a wide momentum probability function and vs versa.
For a particle holding still in one exact spot in one dimension. This can be represented by delta function. The Fourier transform of a delta function is a flat function with equal probability everywhere. So for a particle in one exact spot the momentum has an equal likelihood of being anywhere from minus infinity to positive infinity. This of course is not possible and neither is a perfectly still particle.
Does this help?
As for momentum,it is the quantum observable associated to the classical one.If you can write the classical Hamiltonian of the system,then u need to apply the second postulate (the postulate of quantization) to it.
Daniel.
Yes. I don't think you can understand what momentum in quantum mechanics is unless you understand the whole framework. If you do, you will understand Daniel's answer. If you don't understand the whole framework, then any answer I can think of won't really explain it that much, just give you more words for a concept that you won't understand.
The issue here isn't the uncertainty in a SINGLE measurement (this is limited to the resolution of your instrument and is NOT the uncertainty in QM). The issue here is your ability to predict the outcome of the next measurement, and the next, and the next, and the next...
When you have made a measurement of the exact position, you destroy your ability (to some degree) to predict what you will get when you measure its momentum. You CAN measure it, and measure it with very high accuracy, but if you prepare an identical system, measure the SAME position, you will see that the momentum value you obtain will vary, and can vary widely! If you do this repeatedly, you will see a very large SPREAD in the value of the momentum. Based on this, you cannot say that you know very well what the NEXT value of momentum is going to be - thus, you have a large uncertainty in predicting the dynamics of the system.
Again, I hate being tacky, but I have tackled this misconception about the HUP in one of my Journal entry, where I illustrated this using the single-slit measurement. You may want to read this rather than have me repeat the whole thing here.
Zz.
Your confusion is soundly motivated. Einstein had similar reservations.
He proposed this: You measure the time at which a particle passes
two different detectors, A and B. When it passes B, you now know
what the particle's position AND momentum were all along the way
between A and B.
The problem really IS that you cannot determine momentum and position in
the same place and at the same time.
In QM, momentum is literally determined by measuring the distance
between crests and troughs of the wave function, i.e. the wavelength.
If you have a wave packet which is crammed into one tiny spot AND
the wavelength is about the same size as the spot, you can't count
a lot of crests/troughs, so the momentum cannot be determined accurately.
At the other exteme, knwoing the momentum exactly means having an
infinte number of crests/trhoughs to count. But that means the wave
function is an infinitely long wave in space, so you loose all position
information.
This uncertainty principle is not magical. It happens in a radar when
you try to determine the freqeucy of a very short pulse. If you can only
count a few cycles, you can only determine frequecy with limited accuracy.
1. What is momentum in quantum mechanics?
Momentum in quantum mechanics is a fundamental property of particles that describes their motion and is related to their velocity. It is represented by the symbol p and is quantized, meaning it can only take on certain discrete values.
2. How is momentum related to position in quantum mechanics?
In quantum mechanics, the position and momentum of a particle are related through the Heisenberg uncertainty principle. This states that the more precisely we know the position of a particle, the less precisely we can know its momentum, and vice versa.
3. Can momentum be observed in quantum systems?
Yes, momentum can be observed in quantum systems through a process called momentum measurement. This involves using a device called a momentum operator to measure the momentum of a particle. However, the act of measurement can change the momentum of the particle.
4. What is the significance of momentum in quantum mechanics?
Momentum is a crucial quantity in quantum mechanics as it is conserved in all interactions between particles. This means that the total momentum of a system of particles remains constant, even if individual particles may change their momentum. It also plays a role in understanding the behavior of particles at the quantum level.
5. How does momentum affect the behavior of particles in quantum systems?
The momentum of a particle affects its behavior in quantum systems in several ways. It determines the particle's wavelength and can affect its probability of being in a certain location. It also plays a role in determining the energy of a particle, as well as its speed and direction of motion.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
