What is Nothing vs Absolutely Nothing?
  • Thread starter Erck
In summary, according to this theorist, the concept of nothing does not exist. Matter has no tensile strength to speak of and the concept of space does not exist within the bounds of "nothing".
  • #351
I believe I have described the quantum field as a matrix (that create space) with a set of atomic operations (that create time). This is a mathematical model that can account for any the effects of any theory.
All numbers stem from binary activity, i.e. one after the other, one after the other, one after the other, one after the other, one after the other.
The distance between whole numbers is the same, numbers have a circular (regular intervals) nature.
Modern physics is about studying fluctuations in the relationships of component parts in an enclosed observation moving through space.
(Note I said the observation was moving as well, what I mean is - if we observe something, our 'point of focus' [the observation] moves with it.).
  • #352
Also numbers are relative from your framework, point of view or goal. For example numbers can refer to steps (cfr. in Catalan numbers) or can refer to identical units (distance like you call it).
  • #353
connect: 1- Its impossible to have 2 different events happen in the same space at the same time. This by defintion makes it the same event.
2- Its impossible to have 2 different events happen at the same time in the same space This by defintion makes it the same event.
the first one I agree with, but the second Is not true. for I can have a rock, say its green, and it weighs, has momentum, and is a tempeture. so I can have now 5 different events happen at the same time, and the are linked to one event but they themselfs are 5 different events each independent. we can call the rock a pet plane, and art lumes, or even humor.
  • #354
The examples given are logical equivelants, i.e. 2 ways of saying the same thing!
The 'five events' you refer to are actually properties or aspects of that event, i.e. the sum of the observers properties = the total of the observers subject object.
Everything is fluxuation so cannot really have a 'fixed' weight in motion, only in a single point of time. A point has no distance it is just a perceptial horizon, i.e. is part of the observers reality.
  • #355
but time is an event too, for it exists, and their is no single point of time unless your going the speed of light. you replace frame rate, with the term event. for time is fluid with the speed one is traveling, and one is always traveling at veriable speeds, and temp., ect., say for instance the center of our Earth is ageing differently then us on the serface, and is a linked event of speed.
hmm.. what if I then spray the green rock black heat it up till it fractures, cool half the fracture with liquid nitrogen, and heat the other half back up to melting, squish them together, dance around sining labamba with on foot straped into a snowbaord, trying to make the rain god bring bearded frogs to over take the world, I through the rock as a sacrafice to the rain god, but to my dismay he didnt reach far enough and it knocked myself out to stop the event from even happening.
is that considered one event too? think this kind of falls under the whole, is god real thing, were god = all. but see if all = all , then all can only explain all and cannot explain the inner workings of the linked events to cause a car to run, or for life to breath.
thier for if any said event is said, it then exists within the physical.. so I just saved the world :D on accident, you all better be grate full hehe .
see connect under that principle a stream of events could be called one event, but its not one event for every aspect is an event separet from the other, when I heat up a rock it expands as it gets hotter, that is a linked event or one event. but to call a green rock the same event as a rock that is say in my front yard going around the planet the same event. in general they are effecting the same object, but I could paint the rock red set it back down, and the event of rotation wouldn't be effected at all. their for the connection between the events is not of the same linked point.
see what I'm getting at?
  • #356
All "things" are events, of course.
Time itself however, is not an event. Nor is space.
All events happen in space, separated by distance, because of time.
Space and time are contained within something else.
  • #357
Why?
Contained in what exactly?
It appears to me that space and time are a bit more consistent than we are.
It also appears to me that we actually live in and are defined by space and time?
  • #358
I agree we live in space and time... but it doesn't mean they aren't contained in something else.
If I told you, I'd have to shoot you. :)
  • #359
Im just trying to find the basis for 'space that exists outside of other space'.
If you think about that, it just means that 'on the outside of one space there is other space'.
Ill put it to you again that 'it is only possible to have space'.
Or a bit more refined 'it is only possible to have different types of space configurations relative to other space configurations'.
These space configurations are in constant flux, changing, from one to the next, hence time.
I think its one of those things that is so obvious it is taken for granted and forgotten.
Im bullet proof (to a certain extent...)
  • #360
If space and time are 'contained' inside of something else, what contains the 'container'? Kind of defeats the whole notion of a 'universe' when you rely upon external entities to explain it. For the most part, that just neatly avoids the question.
  • #361
The container is the container.
The question is... "what is the container?"
What is it that has no "outside?"
If space/time is the container... given enough time and space, one will always encounter more universe... never reaching the container.
Not to mention not being able to answer the question of whether it's always existed or was created from a condition that didn't include space/time.
Working with "space/time or universe" to find the container is most likely fruitless.
Endless circles leading nowhere.
  • #363
It wasn't much of a theory to begin with.
It couldn't find the beginning, much less before the beginning.
  • #364
  • #365
I would suggest a black hole and the big bang are the same.
They both surmise that something and nothing can interchange. One goes from something to nothing... one goes from nothing to something.
Niether seems to be that case.
Or am I misunderstanding it?
  • #366
I think you are misunderstanding. These categories are not specific enough to distinguish things that are really different.
The black hole does not go from something to nothing, it's just one-way. What goes in can't get out again.
In the black hole, spacetime geometry is pretty fixed, in the big bang, spacetime is expanding rapidly. The physics is completely different. And I repeat that Hawking's talk was specificllly about interacting with black holes, not anything at all to do with the big bang.
  • #367
selfAdjoint said:
The black hole does not go from something to nothing, it's just one-way. What goes in can't get out again. And I repeat that Hawking's talk was specificllly about interacting with black holes, not anything at all to do with the big bang.
I realize his talk had nothing to do with the big bang.
I also realize that it's not commonly thought of that the big bang and black holes are the same thing... but I think they are representations of each other. The big bang being the macro and the black hole being the micro.
Doesn't Hawking's old theory state that what goes in disappears (albeit into another universe, theoretically), and isn't just trapped?
The power of a black hole to suck up stuff and make it disappear is very akin to the idea of a black nothingness being able to make stuff appear.
The new idea that black holes leak stuff back into the universe is like saying that somhow something leaks from nothing and the universe begins.
The new black hole theory has some strong merit... but it's dealing with a pre-existing relative state... the big bang theory doesn't have an ounce of merit since it's trying to deal with an absolute state which is quite different.
  • #368
I think the big bang is a metifor for nothing befor this matters. not because of nothing or time, but because if any previsous other universe existed it wouldn't effect this universe. see what I think happened is: a complete unversal expansion, meaning the big bang occurred and is beyond extendable limits for life, and say one atom just going in some direction, at some speed. and say their were another univere were the same is occured, and a single atom million trillion light centuries (cool made up a new thing? maybe don't know) apart from any other atom from its universe, travleing at some speed acording to its universe. and they collide, now our universe has its own idea of what speed is, and so does the other universe, which is to say 20 mph here could mean 100 * C thier. if it weren't then maybe they would just bounce off each other.
if this occures then a huge big bang would occur to disperse the energy of the collision. and a black hole is just what a black hole is, a gravity death trap created by a colapsing something, star or whatever.
isnt that the way the atomic bomb works thou? like doesn't it cause space time to bend at the moment of the 2 element impact, cause one has got to be going near c., oh well nvm, way too tired to think anymore night.
  • #369
'a priori' assumptions cannot be proven within the theory that assumes them [a Godel thing]. It is simpler to apply the quantum model to the universe as a whole. Which is to say the universe arose from quantum fluctuations in the 'nothingness' that preceeded it. This particular universe resulted from a fluctuation that had just the right properties to evolve into the structures we now observe. This reality is, therefore, the sum of all possible histories.
  • #370
Can't have a fluctuation or anything else in nothingness.
Explaining this universe using other universes doesn't get us down to the bottom of it.
There are essentially, only two choices.
Explain how something came from nothing without using any other thing in the explanation.
Explain how something has always existed without using another thing as it's source.
  • #371
OK, let's try this again.
Time is only the measurement of movement thru space. Time = the length of space that one thing travels in an agreed counting system. Let's say 88 hart beats = 60 units and the speed of light = 299,792,458 m / per unit or c / t so time has no value without movement.
Lets keep in mind that if you’re the one moving (you are) thru space, you use time(t) as a measure of that movement. c = the t it takes for light to move 299,792,458 m measured from where you.
Space is a place that c travels in. We use t to measure c units of space as a way to give the mind a grasp on what it is not able to grasp on it's own.
I.E. a light year =c * sec * min * hour * day * 365.4 Time is a name that only places
one at a place in space when that space is at that place...
Just how fast are we moving any way?
:rolleyes:
  • #372
This statement is true in the context of Newtonian physics. It is false in the context of the theory of relativity.
  • #373
Prometheus...
How would you restate it in the context of the theory of relativity?
  • #374
Two forms of nothing
There are really two forms of "nothing": 1)rational nothing-nothingness by definition and 2)empirical nothing-what could be there when one is at the limit of ones senses or sensors but detects nothing. In a rational system, something can either come from something or nothing but not both, otherwise, they would mean the same thing instead of being opposites. Because our senses and sensory devices are finite, we can never be empirically sure we have seen the smallest thing. Things can appear from "empirical nothing" but not from "rational nothing."
  • #375
Self-contained entities do not have to be contained. There is currently nothing readily available to demonstrate that our universe is in a container. Your question is equivalent to asking: God created everything and what created God? The Container-container theory as it is sometimes called always leads to what is known in philosophy as infifnite regress. The sausage inside sausage inside sausage ...ad infinituum!
On the issue of there being such thing as a 'nothing', my argument remains the some: there is none. Nothing remains what it has been, is, and will ever be: nothing. It cannot in reality relate to that which may be wholly construed as something.
  • #376
Self-contained entities do not have to be contained. There is currently nothing readily available to demonstrate that our universe is in a container. Your question is equivalent to asking: God created everything and what created God? The Container-container theory as it is sometimes called always leads to what is known in philosophy as infinite regress. The sausage inside sausage inside sausage ...ad infinituum!
  • #377
There is also nothing readily available to demonstrate that our universe is the container.
I think the task is to define "container."
Is it impossible to logically define the container that isn't contained?
Given enough time we can theoretically reach the first or last thing in the universe and peer out over more space.. inside of what?
What comprises the "edge" of the universe?
  • #378
Well, on the physical side side of things, you are right, there is currently no analytical tool or procedure to substantiate it. But on the supernatural side of things, you probably know that there are those who always use the 'First Mover Argument' in philosophy to equivalently attempt to substantiate it. I am skeptical as to the possibility of both.
  • #379
I agree with your observation about emperical-nothing...it's a mere signal to observational or visual limitations. I believe that there has never been any accountable relation between something and nothing at any level of contemplation. Our constant ettempt to make such connection is fictional and has no base in reality.
Even a rational system, if it is to make any sense at all, has a base in reality. My own examination informs me that even in a rational stage there is no room for nothing. Something always comes from this thing or from every other thing and not from nothing. This controversy has caused headache in may areas of philosophy and I beg you understanding to steer clear of it. You might say to me; such logic sucks! yes, it does. But that's the way the cookies crumbles!
  • #380
I wonder if sufficient contemplation could arrive at an accountable relationship between something and nothing... and if that "idea" would be so compelling that it would be taken as "fact?"
  • #381
Perhaps...and it's debatable whether only under sufficient contemplation could one draw such an amazing 'conclusion', of which you are quite right may be mistaken for a fact. Well, if you like take it as an ordinary suspicion. I am merely expressing my own personal doubt as to whether nothing can give rise to something, let alone any conceivable thing construed as something able to take the form of 'nothing'.
  • #382
I'm actually not questioning your doubt as to whether nothing can give rise to something... nor am I assuming that a very fundamental idea can only be "mistaken" for fact.
I'm actually wondering if at the root of existence... idea and fact are the same thing?
Plato "seems" to suggest it when he said... "and idea is an archetype of which a corresponding being in phenomenal reality is an imperfect replica."
  • #383
Erck said:
II'm actually wondering if at the root of existence... idea and fact are the same thing?
Plato thought that geometry is perfect. The reason that it doesn't correlate well with the real world is due to imperfections in the real world, not with his perfect model of geometry.
Do you agree?
  • #384
My feeling is that they are both imperfect... the geometry and the real world.
True perfection only happens once.
That's the nature of perfection in it's truest sense... at the fundamental level we are talking about.
Anything inside the universe including geometry, and probably the universe as a whole, is not the singular perfection I'm referring to.
  • #385
nothing is the absence of personal,group,country of things but that others have.
absolute nothing is the absence of space,time and dimension,therefore with absolutely no possibility of bringing forth any something, seen or unseen.
  • Other Physics Topics
  • General Discussion
