waqarrashid33
- 77
What is potential devidor and how it works?if anyone have suitable link please add it here.
A potential divider, also known as a voltage divider, is a electronic circuit that divides a voltage into smaller parts. It is commonly used to provide a specific voltage output from a higher voltage input.
A potential divider consists of two resistors connected in series. The input voltage is applied across the two resistors, and the output voltage is taken across one of the resistors. The ratio of the two resistors determines the output voltage.
The equation for calculating the output voltage of a potential divider is Vout = Vin x (R2 / R1 + R2), where Vin is the input voltage, R1 is the resistance of the first resistor, and R2 is the resistance of the second resistor.
Potential dividers are commonly used in electronic circuits to provide a specific voltage for components such as sensors, actuators, and transistors. They are also used in power supplies to regulate the output voltage.
By using the equation Vout = Vin x (R2 / R1 + R2), potential dividers can be used to measure unknown voltages. The known input voltage and resistor values are used to calculate the output voltage, which can then be compared to the unknown voltage to determine its value.
