Strain: What is the Difference Between h/a and h/R?
In summary, the conversation discussed the concept of strain and its relation to the deformation of objects. While the formula for strain is typically defined as the ratio of deformation to the original size, it can be more complex for objects with multiple dimensions. The example of a soft ball against a rigid surface is not the best way to understand strain, and it is recommended to instead think of it as the amount of deformation per unit length. The shape of the object also affects the calculation of strain, with more complex shapes having different strains in different dimensions. Additionally, strain can be measured in terms of area and volume in 2D and 3D objects.
m00npirate
50
In class we discussed a force exerted on a soft ball against a rigid surface. We were told that the strain (of the order: we are doing dimensional analysis) h/a where h is the height difference from the undeformed ball, and a is the radius of the circle intersection of the ball with the surface. However, on wikipedia it says that strain is the "measure of how much a given displacement differs locally from a rigid-body displacement." Wouldn't this be h/R (Radius of the undeformed ball.) Can someone give a more clear definition of strain?
Thank you in advance.
Be careful using Wiki ...its explanations tend to be quite complex. But the ball/rigid surface example of strain is also not a good start point for understanding strain, because it involves 3 dimensional deformations. Instead, consider strain as the amount of deformation per unit length. Take a rubber band about 10 cm long and stretch it 2 cm so that it is now 12 cm long. The deformation, or stretch, is 2 cm, and the strain is 2 cm/10 cm = 0.2, a dimensionless quantity.
how does one go about finding the strain for more complex objects? My professor pretty much just told us it was h/a with little explanation.
For example in 2 dimensions compressing a soft triangular sheet against a rigid surface (on its point). Isn't the strain again just Δheight/height? Why is it different in different shapes?
For 2D and 3D is it ΔArea/Area and ΔV/V?
The triangle is more complex than a rubber band which has strain in one direction only (of course in the real world it is a bit more complicated than that). Not only does it get shorter, but it will also get wider. So you have two different strains in two different dimensions.
1. What is strain and how is it measured?
Strain is a measure of the deformation or change in shape of a material due to an applied force. It is typically measured as the ratio of the change in length or shape to the original length or shape of the material.
2. What is the difference between h/a and h/R strain measurements?
h/a and h/R are two different ways of measuring strain that take into account the geometry of the material being tested. h/a is the strain measured at a specific location on the material, while h/R is the average strain over the entire length or radius of the material.
3. When should h/a strain be used versus h/R strain?
h/a strain should be used when the material being tested has a non-uniform cross-section, such as a bar with varying thickness. h/R strain should be used when the material has a uniform cross-section, such as a cylindrical rod.
4. How is h/a and h/R strain calculated?
h/a strain is calculated by dividing the change in length or shape at a specific location by the original length or shape at that location. h/R strain is calculated by dividing the average change in length or shape over the entire length or radius of the material by the original length or shape.
5. Why is it important to measure both h/a and h/R strain?
Measuring both h/a and h/R strain allows for a more comprehensive understanding of how a material responds to applied forces. It can also provide insight into the behavior of the material at different locations or under different conditions, and can help identify any potential weaknesses or areas of concern.
  • Other Physics Topics
