Homework Help: What is the final temperature?
  1. Jan 31, 2008 #1
    A cup made of 100g of aluminum holds 200g of water at 50deg C, a 10g piece of ice is placed in the cup of water, what is the final temperature?
    2. Relevant equations
    Q=L(f)m
    S=cm lnTf/Ti
    specific heat of aluminum 0.90 J/gC
    3. The attempt at a solution
    I think the first step is to determine S(ice)
    Q=Lm=79.5 cal/g * 10g=795cal
    S(ice)=Q/T=795/273K=2.91
    S(water)=Q/T=-795/323K=-2.46
    2.91-2.46=.45cal/K
    then as 0deg C water goes to 50deg C?
    I believe I should be using an integral as the ice will be changing the temp of the water?
    S(ice)=cmln(Tf/Ti)
    1cal/gC * 10g ln(795/323)=9
    S(water)=cmln(Tf/Ti)
    1cal/gC*200 ln(795/323)=180
    So now I'm confused-because I believe I would need to know the final temp of the water before calculating S with the Steel??
    I also do not understand how to convert J/gC to cal
Draft saved Draft deleted
