What is the flux density at point p?
In summary, The flux density at point p due to the 3-A current in the portion of wire 2 shown is 2.45 x 10^-5 Wb/m^2 and it points out of the page. The correct formula for finding flux density at a point is B=I x 10^-7 (Integral sign) sinΘ/r^2 dl, where dl is written in terms of the perpendicular distance from the wire to the point. It's important to take into account variables like r and to correctly set up the geometry in order to get an accurate result. Online calculators may be helpful in understanding the concept.
Adventure123
What is the flux density at point p in Fig "see link below". due only to the 3-A current in the portion of wire 2 shown?
1) 1.64 x 10^-5 Wb/m^2
2) 2.45 x 10^-5 Wb/m^2
3) 3.11 x 10^-5 Wb/m^2
4) 3.65 x 10^-5 Wb/m^2
2)
In which direction does the flux at point p of Question 1 point
1) Out of the page.
2) To the left of the page.
3) To the right of the page.
4) Into the page.
Fig Link
sellmontana.com/math/math.jpg
ignore the red marks.
Answers 2 and 2.. Is this correct?
Thanks
B= I x 10-7 (Integral sign) sin Θ /r^2 rdΘ/sin0
B= I x 10^-7/0.0200 (Integral sign) sinΘ dΘ
B=.5 x 10^-7 [-(-2)-(-5)] = ??
Does anyone have a real good document on how to Find flux density at a point? My current book does not fully explain it. Is there a online calculator that would help?
Thanks.
Hi Adventure123,
I think you have a couple of problems with your integral. It's difficult for me to tell because I don't know how you set up the geometrey, but here are some notes:
In the first line of section 3, it looks like you are writing dl in terms of d(theta). That's good, but since your expression for dx has r in it, it looks like you forgot to take into account dr (since r is also variable). If so, it would probably be better to write dl in terms of theta and the perpendicular distance from the wire to the point (2 cm in your diagram). If we call that distance x, then dx would be zero.
In your second line of section 3, you brought r out of the integral, but it depends on theta and so cannot be removed like that. (If you write dl in terms of x, that constant x value would come out of the integral.)
But like I said, I could just be misinterpreting your method.
I would first clarify the question by asking for more information about the wire and the point p in the figure. Without this information, it is difficult to accurately calculate the flux density at point p.
However, based on the given information, the correct answer would be 3) 3.11 x 10^-5 Wb/m^2. This can be calculated using the formula for magnetic field at a point due to a current-carrying wire, B=I x 10^-7 (Integral sign) sinΘ/r^2 dl. Since the wire is carrying a current of 3A and the distance from the wire to point p is 0.0200 m, we can substitute these values into the formula and integrate over the portion of wire 2 shown.
Regarding the direction of the flux at point p, it would depend on the direction of the current in the wire and the orientation of the wire with respect to point p. Without this information, it is not possible to accurately determine the direction of the flux at point p.
As for resources on finding flux density at a point, there are several online calculators available such as the one provided by HyperPhysics (http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/magcur.html) or by using software such as Mathematica. Additionally, there are various textbooks and online resources that provide explanations and examples on how to calculate flux density at a point. It is important to have a thorough understanding of the underlying principles and equations in order to accurately calculate flux density at a point.
1. What is meant by flux density at point p?
The flux density at point p refers to the amount of electromagnetic flux passing through a unit area at a specific point p. It is a measure of the strength of the electromagnetic field at that particular point.
2. How is flux density at point p calculated?
The flux density at point p is calculated by dividing the total flux passing through a surface by the area of that surface. This can be expressed mathematically as B = Φ/A, where B is the flux density, Φ is the flux, and A is the area.
3. What are the units of flux density at point p?
The units of flux density at point p depend on the system of units being used. In the SI system, the units are Tesla (T), while in the CGS system, the units are Gauss (G). Other common units include Wb/m2 and Wb/cm2.
4. How does the flux density at point p vary in different materials?
The flux density at point p can vary in different materials depending on their magnetic properties. Materials with high permeability, such as iron, will have a higher flux density at point p compared to materials with low permeability, such as air.
5. What factors can affect the flux density at point p?
The flux density at point p can be affected by various factors, including the strength of the magnetic field, the distance from the source of the field, and the properties of the material at that point. Other factors such as the orientation of the field and the presence of other nearby magnetic fields can also impact the flux density at point p.
