What is the inertia?
Tags:
  1. Oct 4, 2016 #1
    A mysterious crate has shown up at your place of work, Firecracker Company, and you are told to measure its inertia. It is too heavy to lift, but it rolls smoothly on casters. Getting an inspiration, you lightly tape a 0.60-kg iron block to the side of the crate, slide a firecracker between the crate and the block, and light the fuse. When the firecracker explodes, the block goes one way and the crate rolls the other way. You measure the crate's speed to be 0.064 m/s by timing how long it takes to cross floor tiles. You look up the specifications of the firecracker and find that it releases 9 J of energy. That's all you need, and you quickly calculate the inertia of the crate.
    2. Relevant equations
    p=mv
    k=1/2mv2
    3. The attempt at a solution
    i know the inertia is referring to the mass of the crate. will i need to use the chang in kinetic energy equation to solve for mass?
  3. Oct 4, 2016 #2
    BvU
    2017 Award
    Nice story. Good thing the crate wasn't full of firecrackers or pure gunpowder (not unthinkable in such a company...).
    Teacher must have had a good time composing it. He doesn't tell you how much of the 9 J is converted to kinetic energy, but I guess you should assume 100%. So the crate comes away undented and undamaged.
    Yess, the exercise wants the mass of the crate. Aside from your two equations you'll need a bit more: energy conservation, momentum conservation, to name some. Start your attempt at solution and post when stuck ...
  4. Oct 4, 2016 #3
    I like Serena
    Hey Emily! ;)
    We have 2 unknowns: the mass of the mysterious crate, and the speed of the firecracker after the explosion.
    To find them we need 2 equations.
    Can we set up the equations for conservation of momentum and conservation of energy?
  5. Oct 4, 2016 #4
    mc(vci-vcf)=mb(vbf-vbi)
    vci-vbi=vbf-vcf
    would i be using theses? for the second equation i divided out mass and the 1/2 and rearranged a bit
  6. Oct 4, 2016 #5
    I like Serena
    The first, yes, and we already know that the initial velocities are zero.
    The second equation doesn't look right. I doesn't seem to be related to energy.
    Oh, and it's too early to divide out mass or the 1/2. First we need to relate it to the given 9 J of energy.
    I don't see how it could ever be 100%. ;)
    Instead I'm assuming we're only given the part of the energy that is converted to mechanical energy. That is, I think the word "mechanical" was accidentally omitted in the problem statement.
  7. Oct 4, 2016 #6
    BvU
    2017 Award
    That is not very wise: the mass of the crate is quite different from the mass of the block.
Have something to add?
Draft saved Draft deleted
Similar Discussions: What is the inertia?
Loading...
