What is the kinetic energy of a proton when neutron decays?
In summary, the proton in the decay of a neutron has kinetic energy given to it by the electron's negligible kinetic energy.
llatosz
62
What is the kinetic energy given to the proton in the decay of a neutron when:
a) The electron has negligibly small kinetic energy
b) The neutrino has negligibly small kinetic energy
Q = (mn - mp - me - mv ) c2 = .782MeV
Where T is kinetic energy, and the neutron is at rest:
Q = Tp + Te + Tv
Now my thoughts are similar for both part a) and b):
For a,
if the electron has zero kinetic energy, then by conservation of momentum, the proton and the neutrino must have equal and opposite momentums. But from lecture, my professor explicitly wrote:
Since mp >> me, and mp >> mv,
Tp << Te, and Tp << Tv, so the Q value is practically
shared between the electron and the neutrino.
and when Tv = 0, Te = Q
So is this a trick question then? Is the kinetic energy given to the proton always going to be essentially zero in part a) and b) , since it is so massive?
Perhaps, but you have enough information to find out, so try it.
Likes llatosz
Are you sure? I have 2 unknowns. By conservation of momentum I have
mp vp = ∂v mv vv
But i don't know vp or vv. But wait! Could I maybe say:
P=momentum
Pp = -Pv = P , and then say
Q=Tp + Tv
Q=sqrt(P2c2 + mp2c4) + sqrt(P2c2 + mv2c4) = .782MeV
and then solve for P!? which i can then use to find just the kinetic energy of the proton!? :D
mp vp = ∂v mv vv
P=momentum
Q=Tp + Tv
Yes. If the electron has negligible KE then it certainly has negligible momentum.
Likes llatosz
Awesome! I appreciate your help very much! I couldn't have done it without you!
Actually, I am getting THIS so i want to convert my 0.782MeV into 8.395x10^-4 amu*c2 by dividing by 931.5. If i do this, my units of momentum would be mass and speed, which is good, right? Or do you think it changes things with all the exponents to the 8th, 4th, and 2nd mixed in?
I am no quantum theorist so I may have this wrong, but it seems to me you already subtracted out rest mass energies to arrive at Q.
Shouldn't it be something like
##\Sigma \sqrt{(p_i c)^2+(m_i c^2)^2}## is constant, where the sum is over the particles, and the mi are their rest masses?
Well wolfram is saying P equals a momentum of 4.89x1036 amu*(m/s)2 = 8.13x109 kg*(m/s)2 which does not seem reasonable because the proton is heavy and should not act relativistic... But i could be wrong about that. I am not very certain of these things either since I am in a class 2 semesters ahead of all the other classes I am in and i skipped the pre-requisites lol.
You are right, your equation
is correct, but in this case, there are only 2 particles, and their momentums must be equal so my equation that i asked wolfram to solve actually fits your generalized equation, and should be correct too.
But its 4:30am here so I am just about done with this problem anyway lol. Unless you have a breakthrough epiphany type of solution idea then i think i should be fine haha. I have the concept down much better now and I owe it all to you for helping me get to the realization of
and just a small numerical error shouldn't have me losing too many points
I still don't see that. What follows is for case (b).
I am saying
##m_Nc^2=\sqrt{(pc)^2+(m_Pc^2)^2}+\sqrt{(pc)^2+(m_ec^2)^2}+m_{\nu}c^2##
Not sure because I thought it was unclear whether neutrinos have mass.
Edit:
Since pc is to be found, we can write that in the form ##E=\sqrt{x+a}+\sqrt{x+b}##.
From that I get ##4E^2x=E^4-2E^2(a+b)+(a-b)^2##.
Likes llatosz
haruspex said:
I still don't see that. (What follows is for case (b). Not sure about (a) because I thought it was unclear whether neutrinos have mass.)
I am saying
##m_Nc^2=\sqrt{(pc)^2+(m_Pc^2)^2}+\sqrt{(pc)^2+(m_ec^2)^2}##
Oh that's interesting! so this equation says the rest energy of the neutrino equals the total energy of the proton plus the total energy of the electron?
No, sorry, I made a mistake.
Correcting...
Ok, I've corrected it. mN is the rest mass of the neutron. But on the right I left out the rest mass of the neutrino... does it have any?
Oh no worries at all. Maybe the N stood for neutron? But I have to get some sleep now. But please do continue i am very interested! I will be up in about 3 hours
A suggestion about how to interpret this problem. The decay into three particles has too many variables to give a unique solution, hence the assumptions. In part a) you assume that the electron has no KE or momentum and, I suggest, assume that the neutrino has a velocity close to ##c##. This means that the energy and momentum of the neutrino are: ##E_{\nu} = \gamma mc^2## and ##p_{\nu} = \gamma mc##., hence ##E_{\nu} = cp_{\nu}##
This means that the neutrinos act like a photon in the energy-momentum equations and you don't need to know its small rest mass.
Part b) effectively means that no neutrino is produced, given that its rest mass, KE and momentum are negligible.
mp vp = ∂v mv vv
P=momentum
Q=Tp + Tv
Another suggestion. In these problems, it's best to work with the energy and momentum for each particle and calculate the overall energy of the particle you want. If you split the energy into mass-energy and kinetic energy too early, it tends to get messy. Note that once you have got the energy of a particle, then you can get the KE simply by: ##T = E - mc^2##.
Finally, there is actually a fairly simple general solution to the problem of decay of a single particle into two. So, the answer here should not be too complicated (although it's not so easy to get to that simple answer). The trick here is see that in part a) the electron is at rest, so its mass can effectively simply be subtracted from that of the neutron. So, I would set the problem up as follows:
Energy conservation: ##E_n = E_e + E_p + E_{\nu}##, hence ##E_{\nu} = (E_n - E_e) - E_p = E_0 - E_p##
Where, for part a), I've used ##E_0 = E_n - E_e = (m_n - m_e)c^2## to keep the equations as simple as possible.
Then, I would square this equation to get:
##E_{\nu}^2 = E_0^2 + E_p^2 - 2E_0E_p##
Now, use conservation of momentum to aim for an equation for ##E_p##.
Likes llatosz
Okay I hear you out and I agree that the neutrino should have a velocity close to ##c##, but if we treat it like a photon, then
##E_{\nu} = cp_{\nu}## would become
##E_{\nu} = chf## where ##f## is the frequency of the photon.
How could we possibly know the frequency of the photon/neutrino?
The energy and momentum of a particle are related by:
##E^2 = p^2c^2 + mc^4##
In the case of a truly massless particle or a particle of negligible mass, this reduces to:
##E^2 = p^2c^2##
This gives the energy of a photon (or a neutrino). There is absolutely no reason to start introducing the frequency of the photon (or neutrino) into the equation.
Likes llatosz
Edit:
Brilliant! Your math checks out
##E^2 = p^2c^2##
You're right, I found that out. I already got my answers and I am confident in them. Thank you very much :)
Summary for future readers looking for the guidance more consice:
Using these equations in the order they are written would be helpful for both parts but part A specifically
##Q=({\Delta}m)c^2 = .782##MeV
##Q = E_n = E_p + E_{e^-} + E_{\nu}##
##Q = E = \sqrt{x+a} + \sqrt{x+b} + d##
where ##x=(Pc)^2##, ##a=(m_pc^2)^2##, ##b=(m_{\nu}c^2)^2=0##, ##d=(m_{e^-}c^2)^2=.5114##MeV
The electron has only rest mass energy because its kinetic energy is said to be zero. ##Pc## is the same for both the proton and the neutrino because momentum must be conserved and equal if the electron has zero momentum.
Finally,
##(Pc)^2 = x = \frac{(a-d^2+2dE-E^2)^2}{4(d-E)^2}## and using momentum, one can find kinetic energy
All credit goes to haruspex and to PeroK.
PeroK has an excellent explanation on the final post on page 2 as well!
##Q = E_p + E_{e^-} + E_{\nu}##
No, that is not right. The total energy is conserved.
##E_N = E_p + E_{e^-} + E_{\nu}##
Oh, thank you. Fixed.
Again though, thank you for all your help, you're a lifesaver. I understand how to use these equations so much better now
The following is a standrad approach for decay into two particles (or three particles where one particle has no KE after the decay). Picking up from post #14:
##E_{\nu}^2 = E_0^2 + p_p^2c^2 + m_p^2c^4 - 2E_0E_p## (Equation (1))
Conservation of momentum: ##p_p = p_{\nu}##
##p_p^2c^2 = p_{\nu}^2c^2 = E_{\nu}^2##
Putting this into equation (1) and simplifying gives:
##E_p = \frac{E_0^2+ m_p^2c^4}{2E_0}##
With ##E_0 = (m_n - m_e)c^2## gives:
##E_p = \frac{(m_n - m_e)^2 - m_p^2}{2(m_n - m_e)}c^2##
And, using ##T_p = E_p - m_pc^2## gives:
##T_p = \frac{(m_n - m_e - m_p)^2}{2(m_n-m_e)}c^2##
Which gives the KE of the proton in terms of the particle masses only.
Note that if there were only two particles after decay (no electron in this case), then we would have ##E_0 = m_n c^2## and the same method would apply.
Note also that if you have the particle masses in ##MeV/c^2##, you can just plug those numbers into that equation to get the proton KE in ##MeV##.
This whole sequence is worth working through and remembering!
Likes llatosz
1. What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion.
2. How is kinetic energy calculated?
Kinetic energy is calculated using the formula KE = 1/2 * mv^2, where m is the mass of the object and v is its velocity.
3. What is a proton?
A proton is a subatomic particle with a positive charge and a mass of approximately 1 atomic mass unit.
4. How does a neutron decay?
A neutron decays by transforming into a proton, an electron, and an antineutrino through the process of beta decay.
5. What is the relationship between a proton's kinetic energy and neutron decay?
In a neutron decay, the proton is created with a certain amount of kinetic energy, calculated using the formula mentioned earlier. This kinetic energy is a result of the transformation of the neutron into a proton and the release of energy during the process of beta decay.
