What is the limit of the moment of inertia of a material line as a approaches 0?
  • Thread starter thomate1
  • Tags
    Limit
In summary, the limit of the expression (a^3 + b^3)/(3ab) as a approaches 0 does not exist due to a vertical asymptote at b=0.
thomate1
1,346
what is the limit of ...
I am a physics student. While I was doing problem concerned with moment of inertia, I got stuck at a point. I got the moment of inertia of a material line as
lim a -> 0 (3ab)/(a^3 + b^3)
What is the limit?
Thanks in advance for your help
The limit for the expression you've written is zero, provided b does not equal zero.
And if b= 0, 3ab/(a^3+b^3)= 0 for all a so the limit is still 0!
Sorry, question was wrong
I am sorry that the question I posed was not what I supposed. I meant
lim a->0 (a^3 + b^3)/(3ab)
It looks like the lim = 0, since a = 0.
Man its been a while since i did this stuff.
Nope. The limit does not exist here.
Since b is in the denominator, so [itex]b \neq 0[/itex]
So
[tex]\lim_{a \rightarrow 0} \frac{a ^ 3 + b ^ 3}{3ab}[/tex]
The numerator will tend to b3, while the denominator will tend to 0. So the limit does not exist.
Viet Dao,
Does that mean there is an asymptote there or something?
Yup, there's a vertical asymptote there.
What is the limit of a function?
The limit of a function is the value that the function approaches as the input approaches a certain value or infinity. It is also known as the "end behavior" of the function.
How is the limit of a function calculated?
The limit of a function is calculated by evaluating the function at values that are very close to the targeted value and observing the trend of the output. This can be done algebraically or graphically.
What is the significance of finding the limit of a function?
Finding the limit of a function can help determine the behavior of the function near a specific value or infinity. It can also be used to determine if a function is continuous at a certain point.
Can a function have a limit at a point where it is not defined?
Yes, a function can have a limit at a point where it is not defined. This is known as a "removable discontinuity" and can be addressed by redefining the function at that point.
Is there a limit for every function?
No, not every function has a limit. A function may not have a limit if it oscillates infinitely or if it approaches different values from different directions at a certain point.
  • Mechanics
