What is the minium force required to pull block C out from under block B?
In summary, the minimum force required to pull block C out from under block B is determined by the static friction between the bottom of C and the floor, and the static friction between block B and C. This can be calculated by considering the weight of the whole system and the coefficients of static friction for each surface. Drawing a picture can help simplify the problem and make it easier to solve.
tucky
30
Q: There is a mass of a mass A (2kg ) sitting on top of a mass of B ( 4kg), which is sitting on top of a mass of C(3 kg). The static friction between A and B is .5; and between B and C is .5 and between C and the ground is .8. Mass B is tied to the wall. What is the minium force required to pull block C out from under block B?
A: Well I am really confused about static friction, the Normal force acting on Mass C is 9kg*9.8N=88.2 N, and is u static is .8+.3=.13, so therefore the static force is
us.* Normal force = Static force =13*88.2 = 88.2N (is that force it would take to move Mass C?)
sorry I meant that it was .13*88.2N = 11.46N of force, that does not seem right. When you figure the static force, is that the force that it takes to move the object?
please read what i had to say in another thread: https://www.physicsforums.com/showthread.php?s=&threadid=6603
Especially the part about drawing a picture.
Physics is not about plugging in values into formulas and hoping the get the right answer. You must first understand what the problem entails and attack it in an ordially fashion.
Make the problem simple and break is into two parts - the friction on the bottom of C and the friction on top of C.
For the bottom of C you have the weight of the whole system times the coefficient of static friction between C and the floor. On the top of C you have the weight of A and B. times the coefficient of static friction between B and C
Now its just a matter of sum of forces in the x direction.
thank you so much, I was lost. You are right about drawing the pictures, it is just hard to do that on the computer.
tucky
1. What is the definition of force?
Force is a physical quantity that describes the interaction between two objects or bodies. It is measured in units of Newtons (N) and is represented by the symbol F.
2. How is the minimum force required to pull block C out from under block B determined?
The minimum force required to pull block C out from under block B is determined by considering the friction between the two blocks, as well as the weight of each block. It is calculated using the formula F = μN, where μ is the coefficient of friction and N is the normal force between the two blocks.
3. What factors affect the minimum force required to pull block C out from under block B?
The main factors that affect the minimum force required to pull block C out from under block B are the weight of each block, the coefficient of friction between the two blocks, and the surface on which the blocks are placed. Other factors such as the angle of the surface and the presence of any external forces can also affect the minimum force required.
4. Can the minimum force required to pull block C out from under block B be reduced?
Yes, the minimum force required to pull block C out from under block B can be reduced by decreasing the coefficient of friction between the two blocks. This can be achieved by using a lubricant or by changing the surface on which the blocks are placed.
5. How is the minimum force required to pull block C out from under block B related to the concept of work?
The minimum force required to pull block C out from under block B is related to the concept of work through the work-energy theorem. This theorem states that the work done by a force is equal to the change in kinetic energy. In this case, the minimum force required to move the blocks results in a change in kinetic energy, which is a form of work.
