What is the net charge of a metal sphere after electrons are added?
  • Thread starter Missy81590
  • Tags
    Charge Net
In summary, after 6.0x10^13 electrons have been placed on a metal sphere with a charge of +8.0 micro coulomb, the net charge on the sphere is -1.6 micro coulombs. This is found by multiplying the number of electrons by the charge of a single electron and adding it to the existing charge on the sphere. Electrons always have a negative charge.
Missy81590
A metal sphere has a charge of +8.0 mirco coulomb. What is the net charge after 6.0x10^13 electrons have been placed on it.
N=q/e or Coulombs Law F= k q1q2/r^2 e=1.6x10^-19
Okay.well i know a mirco coulomb is 10^-6 So i figured you would multiply 8.0^-6 by 6.0^13 and then divide by electrons. But it doesn't seem to get the correct answer. The answer is -1.6 Mirco Coulombs but i don't know how to get that answer. It seems to be just mulitplication or divison, but i tired a 100 different ways, and i can't get -1.6Mirco Coulombs. Can someone help? Thank you!
-Missy
How many microCoulombs of charge does this equal? What is the sign of this charge?
if you divide 10^6/6.0x10^13 you get 1.67x10^<b>-8 </b>. It seems like this is so simple. I must be overlooking something. it means I'm still off my a little bit
How much charge do you have with 6.10^13 electrons? Do you know what the charge of a single electron is? The first step to this problem is figuring out what charge you are adding to the sphere.
The charge of a single electron is 1.60x10^-19. I put that in the given of the problem. And it 6.0x10^13. So i would think you would have mutiply 6.0x10^13 electrons and the charge of a single electron and then divide by the sphere. But that still gives me the wrong answer. It gives me 1.2mircoC but then anwser should be -1.6mircoC
Why would you 'divide by the sphere'?? Don't you want to add?
Yes, you would multiply the the number of electrons by the charge of an electron to get the total charge of the electrons you're adding. I don't know why you would then try to divide by the charge already on the sphere. You are looking for the net charge. You have postive charge on the sphere, and are adding negative charge. So what charge would be left over?
Ah okay. That makes sense. Thank you <b>So</b> much! One last thing. Why would the other charge be negative? i know that a single electron can either be postive or negative, but i don't understand why, because obviously in this case it the electron would have to be -1.6x10^-6 for it to be -9.6x10^l6 then add the sphere to get the correct answer.
Electrons always have a negative charge!
Perhaps you are thinking of the positron, which is the anti-particle to the electron. THAT one has a positive charge.
What is the net charge?
The net charge is the overall charge of an object or system, taking into account the sum of positive and negative charges.
How is net charge calculated?
Net charge is calculated by subtracting the total amount of negative charges from the total amount of positive charges.
What is the unit of net charge?
The unit of net charge is the Coulomb (C), named after physicist Charles-Augustin de Coulomb.
Can an object have a net charge of zero?
Yes, an object can have a net charge of zero if it has an equal amount of positive and negative charges.
What is the significance of net charge in chemistry?
In chemistry, net charge is important because it affects the interactions between atoms and molecules, which ultimately determines the chemical properties of substances.
