Converting Rectangular to Polar & Polar to Rectangular: Engineering Uses
  • Thread starter ME_student
In summary, the conversation discussed the advantages and applications of using rectangular and polar coordinates in engineering and physics. Rectangular coordinates are often used in introductory physics problems, while polar coordinates are more useful for rotational problems. The choice of coordinates also depends on the physical setup and can make solving equations more straightforward. A practical example of this is demonstrated with the use of central potential V(s) in both Cartesian and spherical polar coordinates. The preference for integration depends on the type of symmetry in the problem.
ME_student
108
of converting a rectangular coordinate to a polar coordinate and changing polar to rectangular?
Where would they use this in engineering?
Mathematics news on Phys.org
In physics, depending on the problem, it is much better to use rectangular coordinates in some problems, polar coordinates in others.
For instance, if you open up most college level physics, the first few chapters are mostly problems done in rectangular coordinates (though sometimes polar is a natural way to describe a physical setup, but often the math is better done in rectangular coordinates). Then maybe halfway through the course, they introduce rotational problems. We usually treat applications in rectangular or polar depending on the physical setup, and the biggest reason is it makes it much more straightforward to solve these equations in the coordinates that fit with the situation.
Okay, thanks.
As a practical example, consider a central potential [itex]V(s)[/itex], which depends only on the distance from the origin.
In Cartesian coordinates [itex](x,y,z)[/itex] we have
[itex]s=\sqrt{x^2+y^2+z^2}[/itex]
whereas in spherical polar coordinates [itex](r,\theta,\phi)[/itex] we have
[itex]s=r[/itex]
Which would you prefer to integrate? ;)
In other words, problems with circular symmetry will typically be simpler in polar coordinates while problems with symmetry about a line will be simpler in Cartesian coordinates.
1. How do you convert rectangular coordinates to polar coordinates?
To convert rectangular coordinates to polar coordinates, you can use the following equations:
r = √(x² + y²)
θ = tan⁻¹(y/x)
2. What is the purpose of converting between rectangular and polar coordinates in engineering?
Converting between rectangular and polar coordinates is useful in engineering for various applications, such as analyzing forces and motion in structures, designing electrical circuits, and understanding fluid mechanics.
3. What are some common engineering uses for polar coordinates?
Polar coordinates are commonly used in engineering for tasks such as mapping and navigation, antenna design, and analyzing circular motion in machinery.
4. How do you convert polar coordinates to rectangular coordinates?
To convert polar coordinates to rectangular coordinates, you can use the following equations:
x = r cos(θ)
y = r sin(θ)
5. Can you convert between rectangular and polar coordinates if one or both of the coordinates are negative?
Yes, you can convert between rectangular and polar coordinates even if one or both coordinates are negative. The equations and steps for conversion remain the same, but be sure to use proper signs for the coordinates in each quadrant.
  • General Math
  • General Math
