Homework Help: What is the ratio of R2/R1
  1. Oct 23, 2012 #1
    Hey guys a problem similar to this is going to be on my exam on Thursday, and i'm a bit stuck.
    A wire of length L and cross-sectional area A, has resistance R.
    What will be the resistance Rstretched of the wire if it is stretched to twice its original length? Assume that the density and resistivity of the material do not change when the wire is stretched.
    However my professor wants us to do this problem as a ration, so he will ask us to find the ratio R2/R1.
    So what I did was
    L2=2L1
    R1=P*L1/A1
    R2=P*2L1/A2
    R2/R1= 2L1P/A2 * A1/L1P
    R2/R1= 2A1/A2
    and now I am stuck.
    Thanks for the help
    2. Relevant equations
    3. The attempt at a solution
  3. Oct 23, 2012 #2
    SammyS
    Staff Emeritus
    Is the volume of the wire after it's stretched the same as the volume of the unstretched wire?
  4. Oct 23, 2012 #3
    I think it would double as well since it is getting longer, but why would the volume have anything to do with the problem?
  5. Oct 23, 2012 #4
    SammyS
    Staff Emeritus
    Yes, the volume is important. It lets you find the ratio of the final cross-sectional area to the initial cross-sectional area .
    If the volume doubles, the the density will be reduced to half.
  6. Oct 23, 2012 #5
    Oh snap. So wouldnt the Area be reduced to half? and then I can make another relation
    A1=1/2A2?
  7. Oct 23, 2012 #6
    Ok that works out since that got me the correct answer, but I don't understand how to put that into a ratio form.
  8. Oct 24, 2012 #7
    CWatters
    The volume is constant as no new copper is being added. If length doubles the area halves.
    The resistance will be proportional to length and inversly proportional to area.
    Write two equations eg
    Rinitial = ???
    Rstretched = ??????
    Then divide one by the other...
    Rstretched/Rinitial = ??????/???
    Some terms on the right (such as the restivity of copper) will cancel.
    Over to you to fill in the missing bits.
  9. Oct 24, 2012 #8
    Watters thanks for the response, and I was able to get the correct answer, just not sure how to put it in a ratio form.
