What is the value of N in the CBH model for electrical conductivity?
  • Thread starter r.sahebi
  • Tags
    Value
In summary, the value of N in the electrical conductivity in correlated barrier hopping model is unknown.
r.sahebi
what is the value of "N" ?
Hi to everyone
in the following equation (electrical conductivity in correlated barrier hopping (CBH) model), N is the density of localized states..
I read these matter in some papers but anyone has reported a value for it.
how i must determine this value?
σ_ac=((π^2 N^2 ε^*)/24) [(8e^2)/(ε^* W_M )]^6 (ω^s/τ^β )
ε^*=ε_1+iε_2
ε^* is complex dielectric constant
ε_1 and ε_2 are the real and imaginary parts of the complex dielectric constant, respectively.
W_M is the maximum barrier height of the material under investigation
τ is the effective relaxation time and the exponent s is related to W_M at low temperature by the relation:
s=1-β=1-(6k_BT/W_M)
k_B is is Boltzmann's constant.
Density of states is either measured or determined theoretically from the (usually approximate) geometry of the system.
i.e. if dN is the number of states between energies E and E+dE, then the density of states is n(E)=dN/dE
Likes 1 person
Hi Mr Simon Bridge
this is an experimental work
we use a LCR meter to find the conductivity that may be obey from the CBH equation
the values of ε and ω are clear but we don't know anything about the value of N
How can i use your suggested relation?
Thanks
What is the aim of the experiment?
Just checking:
... would be: $$\sigma_{ac}=\frac{\pi^2N^2\varepsilon^\star}{24}\left( \varepsilon^\star W_{\! M} \right)^6\frac{\omega^s}{\tau^\beta}$$
The density of states would normally be determined by the model you are using - which is normally based on some assumed geometry for the particular whatsit you are testing. The details should be in your notes.
Likes 1 person
AC electrical characterization
what did you type (Math Processing Error) ?
"AC electrical characterization "?
Seriously - that is what you've got under "Aim:"??
That's not an aim. When you have finished the experiment and the calculations, you should know something specific about the thing you did the experiment on. It is something the experiment is designed to help you find out. That's the aim. You should be able to write it out in 1-2 sentences.
If you don't know the aim of the experiment, then you cannot hope to complete it well.
note: I'm not getting any errors - hit the "quote" button under a post to see the raw text.
Likes 1 person
we want to characterize an organic semiconductor material (synthesized in our laboratory for first time). we study DC and AC electrical and optical properties of this material...
one of my friends referred me to an article of Dr Saleh from Al-Quds University.
now i can complete my calculation
Only with respect to conductivity and "s" equations, in the calculations, we have two unknown parameters: N and Ï„.
an equation for calculating the amount of Ï„ is mentioned in the paper of Dr Saleh.
Dear Mr Simon Bridge,
I thank you sincerely foryour guidance
You still sound like you don't know what the aim of the experiment is.
Now I'm having a bit of trouble about the level this experiment is being conducted at - characterizing a new material would normally by post-grad or at least honors level undergrad in NZ, but you are writing (excuse me) as if you are an undergrad new to the whole "how to write experiments" stuff.
When you design an experiment, or a series of them as you have, you should be able to write down a short statement of the aim(s) of the experiment. "Measure AC properties" is not specific enough. In a paper abstract, you can get away with saying "we characterized the organic semiconductor..." but you to be able to say what you used for the characterization.
But I'll give you an example - I once had to model a semiconductor (then new InAs/GaSb heterojunction fyi). This involved working out the density of states. (The actual experiment involved obtaining a V-I curve for the semiconductor at very low temperatures - the analysis compared with the model.)
The material sample was a flat square ... it's sides very much bigger than it's thickness, putting thickness in z, I used a self-consistent calculation to figure out the energy levels in the z-direction while modelling the x-y direction states as an infinite square well.
This is what I mean about using the geometry to model the density of states.
The exact approach will be different for different materials so I cannot just give you an equation.
Aside: if you want to reference a paper here, you need to cite it or it's useless.
i.e. do you mean Prof. Abdelkarim Saleh?
He's done a lot of work with ZnPc films.
Which paper by Dr Saleh?
He's written lots.
i just say thank you Mr Bridge
I've found the answer to my question
Well done - perhaps you can post the answer and so help someopne else who is stuck in the same place.
Cheers, and Merry Xmas.
σ_ac=σ_tot-σ_dc
in CBH model
s=1-β=1-(6k_BT/W_M)
slope of Ln(σ) vs. ω plot give us the value of "s"
slope of s vs. T plot give us the value of W_M
we must calculate the value of "Ï„"( using an equation that mentioned in the following paper:
Saleh, A. M., et al. "Dielectric response and electric properties of organic semiconducting phthalocyanine thin films." Journal of Semiconductors 33.8 (2012): 082002.
you can download this paper (it is free))
intercept of Ln(σ) vs. ω plot give us the value of "N"
Merry Xmas
Cool - well done.
[note: post #2 sentence 1 option 1 ;) ]
What is the value of N?
The value of N refers to the numerical quantity that is being measured, studied, or manipulated in a scientific experiment or study.
Why is it important to know the value of N?
Knowing the value of N is important because it allows for accurate and precise data analysis and interpretation. It also helps to ensure the validity and reliability of scientific findings.
How is the value of N determined?
The value of N is typically determined through careful planning and design of experiments, where the sample size is predetermined based on statistical calculations and considerations.
What are the factors that can affect the value of N?
The value of N can be affected by various factors such as the type of research being conducted, the nature of the sample, the level of accuracy desired, and the availability of resources.
Can the value of N change during a research study?
Yes, the value of N can change during a research study if there are unforeseen circumstances or if new information or data becomes available that warrants a change in the sample size.
  • Atomic and Condensed Matter
  • Classical Physics
