What is this number? (FORTRAN)
  1. Mar 17, 2013 #1
    Hi,
    I'm writing a program in FORTRAN (my first) to find E and B fields due to a spinning sphere of charge. Anyways when printing out E and B field magnitudes im getting numbers like this: 0.1773372103+245
    What the heck does this mean!? Is it like 0.1773372103 x 10^245?
    Thanks for any enlightenment!
  3. Mar 17, 2013 #2
    The old-school FORTRAN formatting was 0.1773372103E245
    But we don't know which FORTRAN compiler you are using, we cannot see what your format statement was, if you used one, we don't know what your write statement was, if you used one, etc.
    Perhaps for your first FORTRAN program before this program, try assigning a real variable a value and printing it out to see the result. Then try making changes to the value and repeat until you can convince yourself you are sure you can depend on output. If you can find some value that results in output like you have above then that might help explain what is going on.
  4. Mar 17, 2013 #3
    Fortran 90
    Here's a text file of my program. Large portions of it are copied from an example code my prof gave us for a similar one dimensional problem. I'll admit I know nothing about formatting (nor do I have time to learn that in detail).
  5. Mar 17, 2013 #4
    here's the code
  6. Mar 17, 2013 #5
    AlephZero
    Short answer: yes.
    Longer answer: In the first versions of Fortran, the exponent field was defined to be 4 characters long, and formatted as E+dd or E-dd (where each "d" is a decinal digit).
    When computer hardware developed so that floating point numbers might have 3-digit exponents, the format options were changed to E+dd, E-dd or +0dd, -0dd for 2-digit exponents, and +ddd, -ddd for 3-digit exponents.
    That still wasn't enough for some computer hardware (e.g. the Cray supercomputers could represent numbers with 4-digit expoinents) so the format specifier was also given a new option Ew.dEe where the w and d are as before, and e specifies the number of digits printed in the exponent.
  7. Mar 17, 2013 #6
    ok great that's what I was hoping to hear! of course that means something is defiantly wrong with my program but at least now I know. Thanks
  8. Mar 17, 2013 #7
    dlgoff
    You know you're showing your age here? :devil:
  9. Mar 18, 2013 #8
    Mark44
    Staff: Mentor
    Mod note: Copied code in attachment to here.
    Code (Text):
    program ComputeEB
    implicit none
    integer,parameter :: iconst = 6         ! integer used to control the resolution
    integer,parameter :: Nz = iconst*5      ! half the number of zones in each domain
    integer,parameter :: ntot = 3*Nz        ! total number of timesteps
    integer,parameter :: printnum = iconst  ! number of timesteps between data printout
    integer,parameter :: c = 3E8            ! speed of prop in a vacuum
    REAL, PARAMETER :: pi = 3.1415927
    integer :: i,j,k, n, Nzh, numout
    double precision :: x(-Nz:Nz), y(-Nz:Nz), z(-Nz:Nz)
    double precision :: Ex(-Nz:Nz), Bx(-Nz:Nz), Ey(-Nz:Nz), By(-Nz:Nz), Ez(-Nz:Nz), Bz(-Nz:Nz)
    double precision :: Exh(-Nz:Nz), Bxh(-Nz:Nz), Eyh(-Nz:Nz), Byh(-Nz:Nz), Ezh(-Nz:Nz), Bzh(-Nz:Nz)
    double precision :: Jx(-Nz:Nz), Jy(-Nz:Nz), Jz(-Nz:Nz)
    double precision :: v, L, dt, h, twoh, dth, ed, time, Energy
    double precision :: R, rho, omega, Toff, epsilon, mu
    character(len=20) :: filenum
    ! Input parameters and constants
    L = 0.1d0           ! length of half the domain
    h = L/Nz            ! length of each zone
    twoh = 2.0d0*h      ! 2h
    dt = 0.25d0*h/c     ! timestep
    write(*,*) 'stuff = ', v, h, dt
    dth = 0.5d0*dt
    Nzh = Nz/2
    R = .025d0
    rho = 1E10
    omega = 1E-3
    Toff = 8E-11
    epsilon = 8.85E-12
    mu = pi*4E-7
    !  Set up the 3D matrix
    do i = -Nz, Nz
      x(i) = i*h
      y(i) = i*h
      z(i) = i*h
    enddo
    ! Initial conditions
    do i = -Nz, Nz
      Ex(i) = 0.0d0
      Ey(i) = 0.0d0
      Ez(i) = 0.0d0
      Bx(i) = 0.0d0
      By(i) = 0.0d0
      Exh(i) = 0.0d0
      Eyh(i) = 0.0d0
      Ezh(i) = 0.0d0
      Bxh(i) = 0.0d0
      Byh(i) = 0.0d0
      Bzh(i) = 0.0d0
      Jx(i) = 0.0d0
      Jy(i) = 0.0d0
      Jz(i) = 0.0d0
    enddo
    open(unit=11,file='Ex0')
    do i = -Nz, Nz
        write(11,111) x(i), Ex(i) ! write data to file
    enddo
    close(11)
    open(unit=11,file='Ey0')
    do i = -Nz, Nz
        write(11,111) y(i), Ey(i) ! write data to file
    enddo
    close(11)
    open(unit=11,file='Ez0')
    do i = -Nz, Nz
        write(11,111) z(i), Ez(i) ! write data to file
    enddo
    close(11)
    open(unit=11,file='Bx0')
    do i = -Nz, Nz
        write(11,111) x(i), Bx(i) ! write data to file
    enddo
    close(11)
    open(unit=11,file='By0')
    do i = -Nz, Nz
        write(11,111) y(i), By(i) ! write data to file
    enddo
    close(11)
    open(unit=11,file='Bz0')
    do i = -Nz, Nz
        write(11,111) z(i), Bz(i) ! write data to file
    enddo
    close(11)
    ! Evolve
    time = 0.0d0
    numout = 0
    do n = 1, ntot ! Compute E and B
      do i = -Nz+1, Nz-1
        do j = -Nz+1, Nz-1
          do k = -Nz+1, Nz-1
            ! determine if we are within the current
            if (time < Toff .AND. sqrt(x(i)**2+y(j)**2+z(k)**2) < R) then
              Jx(k) = (-y(j)/2)*rho*omega*(1+cos(pi*sqrt(x(i)**2+y(j)**2+z(k)**2)/R))
              Jy(k) = (x(i)/2)*rho*omega*(1+cos(pi*sqrt(x(i)**2+y(j)**2+z(k)**2)/R))
            endif
            ! advance a half timestep
            ! E
            Exh(k) = Ex(k) + (dt/(4*epsilon*mu*h))*(Bz(j+1)-Bz(j-1)-By(k+1)+By(k-1))&
                & - (dt/(2*epsilon))*Jx(k)
            Eyh(k) = Ey(k) + (dt/(4*epsilon*mu*h))*(Bx(k+1)-Bx(k-1)-Bz(i+1)+Bz(i-1))&
                & - (dt/(2*epsilon))*Jy(k)
            Ezh(k) = Ex(k) + (dt/(4*epsilon*mu*h))*(By(i+1)-By(i-1)-Bx(j+1)+Bx(j-1))&
                & - (dt/(2*epsilon))*Jz(k)
            ! B
            Bxh(k) = Bx(k) - (dt/(4*h))*(Ez(j+1)-Ez(j-1)-Ey(k+1)+Ey(k-1))
            Byh(k) = By(k) - (dt/(4*h))*(Ex(k+1)-Ex(k-1)-Ez(i+1)+Ez(i-1))
            Bzh(k) = Bz(k) - (dt/(4*h))*(Ey(i+1)-Ey(i-1)-Ex(j+1)+Ex(j-1))
            ! advance a full timestep
            ! E
            Ex(k) = Ex(k) + (dt/(2*epsilon*mu*h))*(Bzh(j+1)-Bzh(j-1)-Byh(k+1)+Byh(k-1))&
            Ey(k) = Ey(k) + (dt/(2*epsilon*mu*h))*(Bxh(k+1)-Bxh(k-1)-Bzh(i+1)+Bzh(i-1))&
            Ez(k) = Ex(k) + (dt/(2*epsilon*mu*h))*(Byh(i+1)-Byh(i-1)-Bxh(j+1)+Bxh(j-1))&
            ! B
            Bx(k) = Bx(k) - (dt/(2*h))*(Ezh(j+1)-Ezh(j-1)-Eyh(k+1)+Eyh(k-1))
            By(k) = By(k) - (dt/(2*h))*(Exh(k+1)-Exh(k-1)-Ezh(i+1)+Ezh(i-1))
            Bz(k) = Bz(k) - (dt/(2*h))*(Eyh(i+1)-Eyh(i-1)-Exh(j+1)+Exh(j-1))
          enddo
        enddo
      enddo
      time = time + dt
      write(*,*) 'step = ', n, ' time = ', time
      ! Print out data if n equals a multiple of printnum
      if (n .eq. (n/printnum)*printnum) then
        numout = numout + 1                     ! increment numout (number of print-outs)
        write(filenum,*) numout                 ! write integer numout to character filenum
        filenum = adjustl(filenum)              ! remove leading spaces
        open(unit=33,file='Ex'//trim(filenum))  ! create file with appropriate filename
        do i = -Nz, Nz
          write(33,111) x(i), Ex(i)                 ! write data to file
        enddo
        close(33)
        open(unit=33,file='Ey'//trim(filenum))  ! create file with appropriate filename
        do i = -Nz, Nz
          write(33,111) y(i), Ey(i)                 ! write data to file
        enddo
        close(33)
        open(unit=33,file='Ez'//trim(filenum))  ! create file with appropriate filename
        do i = -Nz, Nz
          write(33,111) z(i), Ez(i)                 ! write data to file
        enddo
        close(33)
        open(unit=33,file='Bx'//trim(filenum))  ! create file with appropriate filename
        do i = -Nz, Nz
          write(33,111) x(i), Bx(i)                 ! write data to file
        enddo
        close(33)
        open(unit=33,file='By'//trim(filenum))  ! create file with appropriate filename
        do i = -Nz, Nz
          write(33,111) y(i), By(i)                 ! write data to file
        enddo
        close(33)
        open(unit=33,file='Bz'//trim(filenum))  ! create file with appropriate filename
        do i = -Nz, Nz
          write(33,111) z(i), Bz(i)                 ! write data to file
        enddo
        close(33)
      endif
    enddo
    111 format(2E20.10)
    555 format(2E20.10)
    999 format(2E20.10)
    end program
  10. Mar 18, 2013 #9
    Mark44
    Staff: Mentor
    If you're getting numbers like these, you are probably printing uninitialized variables.
  11. Mar 18, 2013 #10
    yeah I realized that! (along with lots of other issues, haha) thanks
